Old 02-04-2009, 10:37 PM   #37
whiteghetto
whiteghetto's Avatar
Drives: '07 blazing blue hatch
do we have a comparison of automatic 1.5, stock everything
CAI vs SRI?
whiteghetto is offline   Reply With Quote
Old 02-28-2009, 08:12 PM   #38
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Done on a DynaPack dyno.
89.9whp
95.7 lbs of torque
MODS: octane 87. aFe intake, NST underdrive/wt/alt pulleys, blitz axleback, royal purple.
Old 02-28-2009, 09:09 PM   #39
peter, why didnt they run your car to redline....you'd have made more power...
Old 02-28-2009, 09:16 PM   #40
PETERPOOP
PETERPOOP's Avatar
Because I don't know what the redline is. I told him 6100-6200rpms. It already sounded like the engine was going to blow up when i was next to the car. All the other dynos on this thread seem like their power peaks at 6k and dies after that. I don't think it would have made more power.
Old 03-01-2009, 02:20 AM   #41
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
What hp reading were you hoping for? I was hoping to do better than 90 hp for the "before" dyno pulls. I sure expected more than 117 hp for the "after" dyno pulls. It's sobering but I'm glad you did it. Congratulations.
Old 03-01-2009, 02:38 AM   #42
PETERPOOP
PETERPOOP's Avatar
Thanks. I was hoping for ATLEAST 90whp. I probably would have had it if i was running 91, had a header, and it was cooler here in hawaii.
I am hoping for some big gains once I put everything on!
Old 04-01-2009, 09:53 AM   #43
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
Here's mine:
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 04-12-2009, 09:27 AM   #44
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
Custom cat back exhaust, otherwise stock. This thing runs PIG rich from the factory!
Link to dyno: http://www.youtube.com/watch?v=kuryS8r_yGo
The Spectacle is offline   Reply With Quote
Old 04-12-2009, 03:03 PM   #45
PETERPOOP
PETERPOOP's Avatar
Running lean. They gauged the AFR from the exhaust tip. Will update when I get my Wideband AF gauge on.
Old 05-10-2009, 06:46 PM   #46
kngrsll
Apexing Egg!!
kngrsll's Avatar
Completely stock dyno at @56k miles. Only oil changes and one filter change at 30k.
With 20% correction, it was 105.5 hp. The engine has held up very well! Thai said with new plugs and air filter, it would easily gain a few hp too.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 05-16-2009, 11:57 AM   #47
LtNoogie
LtNoogie's Avatar
Manual or AT?
Old 05-16-2009, 12:01 PM   #48
LtNoogie
LtNoogie's Avatar
Nice video. Those dyno guys should have let your engine bay cool off a little between runs. And yes, that seems really rich.
Old 05-26-2009, 08:53 AM   #49
Giupo
Drives: Yaris
Hi guys,
This is my Dyno chart at 0.8 bar of boost , I have made the test in a very hot day 30°C (86°F) with 65% humidity also I have also tuned with 0.9 bar of boost and the results are 206 hp and 239.6 Nm torque
Giupo is offline   Reply With Quote
Old 05-30-2009, 09:03 PM   #50
Treyz
~ ambient one ~
Treyz's Avatar
No way that there is a 20% on that last sheet for a stock Yaris. For crank yes but not wheel so it is correct in terms of wheel hp being at 88whp.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 05-30-2009, 09:12 PM   #51
Treyz
~ ambient one ~
Treyz's Avatar
Decided to attend a Dyno/BBQ day at Perfromance Motorsports today.
They dynoed a Nissan Cube (stock from the dealership directly being they are apart of Smitown Nissan) so I wanted to see if I could beat it ...
Only power mod is the AFE intake and ground wiring kit ... also with the ol' a/t slush box ...
AMBIENTLIFESTYLE
Micro Image
Old 05-30-2009, 09:16 PM   #52
^ nice man, bet that was fun.
I have also tuned with 18 psi of boost and the results are 206 hp and 239.6 Nm torque
18 psi yielded 206 hp? That seems very very low for that much boost. Is it a typo?
Old 05-30-2009, 09:30 PM   #53
Treyz
~ ambient one ~
Treyz's Avatar
lol you confused me a bit Garm.
AMBIENTLIFESTYLE
Micro Image
Old 05-31-2009, 08:31 AM   #54
changchewsoon
Drives: Vios Turbo
193 ps and 275 nm at the wheels @ 16 psi
detailed information of the mod can be found here
WR Yaris Intake Picture & Dyno. WRLEO Performance Modifications 37 04-05-2007 07:02 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
