Old 05-22-2009, 12:50 PM   #19
AlainMikli
AlainMikli's Avatar
Originally Posted by MPC Motorsports View Post
Where did you get them and how much did they cost???
I bought it back from Hong Kong with a Super Awesome deal.....almost half price of the RSVP in US
NICE -- what model BRIDES are those?
driver Side : Eugo II
Passenger : Xax II (Easy for passenger to get off)
To do: Supercharger…
Old 05-22-2009, 12:52 PM   #20
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
i just like that ghost logo......
Old 05-22-2009, 12:55 PM   #21
AlainMikli
AlainMikli's Avatar
Originally Posted by 808_Yaris View Post
niceee seats! install the controller let me know if you have any questions
I dont have time this week, I'm kinda busy
may be Next week~
Originally Posted by scape View Post
from what I remember, the passenger seat has a weight sensor in it, anything over that limit and the air bag light and seatbelt light goes off. removing the seat all together means you removed that sensor in the seat's bottom, and it probably needs to relay the signal. was there any connections you had to unplug while removing the original seat?
There's 4 sensor under the original pass. seat, however, Malaya1121 told me he tried to unplug all of them from the stock seat and plug back in, but still uesless
Old 05-22-2009, 12:57 PM   #22
AlainMikli
AlainMikli's Avatar
take out the plug behind the passenger warning lights... the risk of flying through the windscreen in the event of a crash is a small price to pay in exchange of resting their butts on such sexy upholstery...
I'm plaining to cover surface of the whole part with CF Sticker, of just unplug the light...
But I really want to find a way to by-pass the air bags signals tho
yea i would agree /\
once they sit in those seats, then go back to their stock seats, they will think there life is worthless anyway
But if I can by pass the airbag signal, I can get back my steering wheel & A pillar air bag
Old 05-22-2009, 07:34 PM   #23
AlainMikli
AlainMikli's Avatar
I still have the decal if you want them, $10 shipped to you.
Old 05-22-2009, 09:57 PM   #24
Crandall
H8R
Crandall's Avatar
Drives: 08 White RS
Great looking seats. Your car is coming together nicely.
As for the airbag light, you should be able to undo the clip on the back, or just cut the wires. Either way.
Old 05-22-2009, 10:33 PM   #25
AlainMikli
AlainMikli's Avatar
Yeah, I guess I have to undo the clip and call it a day, haha.
Old 05-23-2009, 12:14 AM   #26
may be Next week~
If you move the sensors over, you also have to move the Occupant Classification ECU, which is located under the front of the passenger seat. There is a calibration that a Toyota Tech can do with the Techstream tool to zero-out the system.
Looking at the service manual and EWDs I believe you can bypass the sensors by supplying 0.2 VDC to the SIG1, 2, 3 ,and 4 terminals (on the 4 connectors that plug into the 4 Occupant Classification Sensors).
Connector U1-U4:
Pin 1 - SVC
Pin 2 - SIG
Pin 3 - SGD
The normal operating range for SIG is 0.2 to 4.7 VDC. If you connect up the 4 sets of resistors, theoretically the light should stop flashing (and I believe that this will be the Passenger Airbag Off mode). If the passenger airbag is on with the resistors in place, flip the 10K and 470 ohm resistors so that the 470 is connected from SVC to SIG and the 10K is connected from SIG to SGD. The service manual doesn't indicate if 0.2 V is empty seat reading or if 4.7 V is.
Old 07-10-2019, 09:40 AM   #27
samhain
Drives: 06' Scion xB
Bump for a killer old thread...any solution for this? I know Micro Image used to sell a bypass but they are long gone. Thanks!
samhain is offline   Reply With Quote
Old 07-10-2019, 09:55 AM   #28
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
The gentleman and scholar that posted just above you, CTScott, created a bypass module that takes care of this issue. I bought one from him when I installed my sparco seats and couldn't be happier with it. I have the link to an off-road motorsports site that stocks and sells them, if you need it. The bypass is awesome. With it, you can enable and disable the passenger airbag with the flip of a switch.
When you have a passenger, you turn it on and when they plug their seat belt in, lights stop flashing and everything works as intended. When you're riding alone, you flip the switch the other way to disable the occupancy sensor on the passenger side and no more airbag or seat belt light flashing. It's an absolute must have for anyone with aftermarket seats. It works for multiple Toyota vehicles since so many use the same passenger occupancy sensor., which is a nice cherry on top.
On Instagram
On Wheelwell
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 08:51 AM
