Old 05-22-2009, 05:26 PM   #19
regal
Drives: 09 Yaris 3 Dr White LB
OK I have a mission thanks.
regal is offline   Reply With Quote
Old 05-22-2009, 06:36 PM   #20
toyo
Drives: toyota
1st gen FTW
toyo is offline   Reply With Quote
Old 05-22-2009, 08:18 PM   #21
SailDesign
Drives: .
I have been driving a Yaris for 2 and a half years, most of the time with decent rubber (Toyo Proxes4), and the word "understeer" just wasn't in its vocabulary. True, the new car with OEM rubber is a little less rail-like, but it is still fine for daily use and a bit of throwing around. And I do enjoy my twisties.
Buy some decent tires, not just the cheapest you could find in the width.
Or trade it in.
Old 05-22-2009, 09:01 PM   #22
Tamago
Tamago's Avatar
Drives: UZJ100
fyi, i aligned my car tonight:
Front
camber L -2.5
camber R -2.5
Toe L .03
Toe R .03
Rear:
Camber L -1.6
Camber R -1.4
Toe L -.12
Toe R -.14
get near these specs and you'll reinvent the car.
i don't recommend -2.5camber, stick to around -2.0 for tire longevity :)
Old 05-22-2009, 09:08 PM   #23
Tamago
Tamago's Avatar
Drives: UZJ100
Tamago is the rear diffrent to compensate for the driver weight?
the car is about a 61/39 split because i removed the interior. you don't want the same amount of camber all around, that puts you back in the same boat as stock (understeery)
honestly, i added ONE washer under the front lower hub bolt mostly to get rid of that nasty toe-in the car has from the factory, and ended up with another .4degree of negative camber. if my new wheel setup poses problems i'll be adding another washer or two to kick that camber number up, most likely closer to -2.0
that toe OUT you see though in the rear.... THAT is what makes the car rotate nicely (just don't fall asleep on the freeway, the car is VERY responsive)
edit: oh i get what you're asking.. the rear different left to right...
well as previously mentioned, the rear axle has NO adjustment for alignment, so you kinda just have to live with the uneven numbers, knowing each wheel has only 409lbs on it, so it's really not THAT heavily loaded
Old 05-22-2009, 10:16 PM   #24
regal
can you adjust the camber DIY or do you need a coputer sensor/alignment machine?
Old 05-22-2009, 10:18 PM   #25
regal
Or trade it in.
You are confusion the term understeer with repsonsiveness. The car definately shifts its weight into the turn and stop the chassis from rotating around a high speed turn. Its still a nice drive though.
Old 05-22-2009, 11:06 PM   #26
Tamago
Tamago's Avatar
Drives: UZJ100
if you're a number geek you'll want to add a washer while on the alignment rack
if not, you can easily add a stainless washer and just re-torque your hubs
Old 05-23-2009, 08:38 AM   #27
SailDesign
Drives: .
No, I am not. PLEASE sell the car.
Old 05-23-2009, 08:41 AM   #28
regal
I'm sorry SailDesign but if you think your Yaris doesn't understeer more power to you.
I've decided to keep the Yaris and try adding camber bolts before I do anything rash.
Old 05-23-2009, 11:03 AM   #29
Lafiro
Drives: 06 Yaris Sedan
Where are you aligning your car? I wish I could do this on the fly, instead of paying toyota $100 some odd dollars for a few seconds/minutes of work....
Trading parts in SoCal Yarice Willing to Buy by private party 0 04-17-2009 10:22 PM
Trading in the Yaris hatchbackkid82 General Yaris / Vitz Discussion 24 09-11-2007 05:59 PM
Trading Car in soon, aftrmkrt parts, Greddy TI-C RShatchback Items for Sale by private party 5 07-18-2007 03:21 AM
Considering trading in one or both of my cars for a yaris... lostmind New YARIS Purchase Forum 22 05-16-2007 12:05 AM
