Old 05-23-2009, 08:28 AM   #19
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
Originally Posted by regal View Post
OK, sounds like you saved me some heartache. Seems my best bet is to wait for the HTS shocks with a very stiff spring for the rear to be developed.
your best bet is to buy some camber bolts and fix that alignment.
Originally Posted by xnamerxx
you nailed it sir.
Old 05-23-2009, 09:38 AM   #20
regal
Drives: 09 Yaris 3 Dr White LB
It it a DIY, or do I have to find someone with special alignment knowlege.?
regal is offline   Reply With Quote
Old 05-24-2009, 09:55 AM   #21
Tamago
Tamago's Avatar
Drives: ZZW30
it is a DIY (the INSTALLATION of the camber bolts) however, with camber comes funky toe numbers, so you'll want to get the car aligned immediately.
you nailed it sir.
Old 05-25-2009, 05:10 AM   #22
regal
I ordered some camber bolts
Old 05-25-2009, 02:31 PM   #23
regal
Is there a DIY on installling the camber bolts (I searched) ?
Old 05-25-2009, 08:19 PM   #24
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Jack up the car, take off the front wheel, break loose both nuts that hold the strut to the hub. Remove the upper bolt, keep the lower one in place. Put in the camber bolt in the upper hole, torque both bolts to spec, replace the wheels and go get an alignment.
All that said, the camber won't help you a whole lot. You need a bigger rear sway bar, and/or stiffer rear springs and more air pressure in the rear.
Do not remove the front sway bar. Your problems will only get worse.
