#109 |
rice rocket
Drives: 05 Echo Join Date: Feb 2007
f-con is different from f-manage. the f-manage is by greddy/trust.
http://www.nengun.com/trust-greddy/f-manage
#110 |
wow parmas, thanks for all the screenshots! think i'll need a while to go look at all of them, nice job by the way! :)
anyways, i've placed an order for a set of recirulation adapter for my SSQV. hopefully i will be able to get my recirculation done within 2 weeks time. i will post up information here for sharing.
454 whp, 1.7 bar boost, pump gas, water/meth. 501 whp, 2.2 bar boost, pump gas + avgas, no water/meth. www.viosturbo.com - World's first 500 WHP 1NZ-FE |
#111 | |
the fcon is a product from HKS,the fcon IS and the fcon SZ are piggybacks while the fcon VPro is a standalone ems. the f-manage is a product from trust, it is a wideband O2 monitor and it also allows you to tune your car's closed loop by modifying the air fuel ratio signal the ecu is currently receiving from your O2. i came across in the magazines that the japanese and taiwanese are using the f-manage to control the closed loop feedback of the skyline R35 as the r35 runs a full time closed loop system even when you're on WOT.
#112 |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
made another video for you guys! http://www.youtube.com/watch?v=26ybx...eature=channel
#113 |
cool. Why does it run so rough?
#114 |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
#115 |
nice video!
by the way, i just want to share that although my tuner thinks that doing a recirculation is the fastest and easier way, he provided an alternate option if i wanted to stay venting to atmosphere which is to perform a MAF sensor relocation to a pre throttle body and post bov location.
#116 |
#117 |
Just a thought where I can get some information about general ecu mapping and tuning. I want to consider tuning my engine myself but I need to get the know how when and why etc...
If any of you have any link to some website or if any of you is already a tuner himself could give me any tips would be much appreciated! |
#118 | |
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
#119 |
Today I tried to understand by myself how to manage fuel and ignition. Well the tuning is fair easy to control and to manage but there are some things I still don't understand.
First I am confused what is the difference between micro fuel injection and normal fuel injection? What about Injectors constant and latency values? From where do I get them? Acceleration map, sensitivity and decay? Second how could I understand when the ignition map is ok at that particular rpm? (In the ignition map shows constant ignition on all rpm loads) What about ignition angle and coil charge time? Is there any need to change? What is the best to reference on the mainfold air pressure sensor or throttle position sensor? I know there are many questions here but I would be pleased if some of you can make me understand more as much on these! |
#120 |
Who said Yaris was slow?
Not to pull you back.... but,
With ALL the money and time that you have invested on this car so far... are you going to cheap out on the most critical stage???? If I were you I would go for a Pro tune... You know you can kill your engine with a bad tune?? It would be a shame! Is cool if you want to learn about tuning... but perhaps you can pick up a beater car and practice on an engine that you wouldn't mind to screw up. Just my 2cents |
#121 | |
On the other hand if the tuner makes a bad tune himself I would be more shame to pay for his time (which is not cheap btw) Also I am considering that if it happen to notice a misfire on a particular gear and rpm I would be able to set it myself. I know I am not a tuner myself and I don't pretend to set all the rpm loads on all gears by myself |
#122 |
Good luck to you then! just be careful
#123 | |
Bathroom + Laptop = <3
#124 |
Thanks for your answers ... here is the setup screen where you can select which load input the ecu has to refer on as primary input
You can refer to the previous page to see some screenshots maps from the ecu |
#125 |
Well if you don't have a map sensor installed you can only do it based off the throttle position sensor....
but if you do have a MAP sensor that you added, it should be TPS for whatever is out of boost and MAP for when it hits boost. So it would be one of the bottom two... |
#126 |
What do you think about ignition compared with fuel injection?
And btw what is micro fuel injection? |
| Motor Longevity | Pavel Olavich | DIY / Maintenance / Service | 10 | 03-17-2012 12:43 PM |
| cali yaris built motor | cali yaris | Performance Modifications | 83 | 09-04-2009 12:08 AM |
| Fan motor noise... | 500snakz | General Yaris / Vitz Discussion | 10 | 12-01-2008 03:43 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
| Exchanging Motor on a Liftback 1.3 Lt | weckjuan | Performance Modifications | 8 | 11-12-2006 11:58 AM |
