#19 | |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
What does it do? What is the difference between and engine designed to use synthetic and one that is not? What synthetics do not meet mfg oil standards? When you are breaking in an engine you are seating the rings. As the rings seat engine compression levels rise until the rings are fully seated. improper break in, like driving your car like a pansy will not product high enough combustion pressure to force the rings out to properly seat. Proper break in is very important and 90% of it is done within the first 40 minutes of running the engine. The main things to avoid are steady cruise speeds, idleing, overrevving, or short trips under 5 minutes. After a tank of fuel the rings are pretty much seated as much as they will (depending on how it was run) Everything else like bearings and valve guides are precision machined to exact specs. Again these are not engines from the 70's Running in an engine does not in anyway shape or form take 20,000km For phuck sakes man some people don't put 20,000km on their car in a year... My sister in laws Cobalt is 2 years old and does not have 20,000km. The difference between oil is this Group I = Conventional oil is group I oil (basic refined mineral oil) Group II = Synthetic blend is a group II oil and is a mixture of synthetic base Group III = highly refined crude oil but is classed as full synthetic and usually contain low to moderate levels of POA's and Esters (Mobil 1, syntec, Motul ) Group IV lubricants are pure synthetics POA based and contain no mineral oil (Amsoil Royal purple) Group V lubricants are polyolEster based and also contain no mineral oil (Amsoil and Redline) Any one of these oils can be used in ANY automotive engine, most if not all meet or by far exceed mgf oil requirements. Some engines like in Cadillac, lincoln, BMW, Corvette, lexus, etc come with synthetic in them NEW off the showroom floor. Why do Toyota dealers offer Mobil 1 for oil changes? Please befor you make yourself look real stupid just stop talking about what you don't know anything about ! The fact is engine wear out, and using a better lubricant will greatly extend the life and performance of the engine. instead of an engine running 300,00km and burning oil, large loss of compression and overall loss of performance with TRUE synthetic you can greatly reduce the ring and cylinder wear, friction, heat and because there are no by products to oxidize and turn to sludge performance and oil flow is not lost doe to engine deposits. With my race engine using EGT/CHT ive seem as much as 30degree drop in egt's just by switching to Amsoil. I went from rebuilding our drag and race engines every few races to once a season or longer.
The early bird gets the worm, but the second mouse gets the cheese. Last edited by 07WYarisRS; 10-24-2006 at 02:57 PM. |
#20 | |
HardlyDangerous
It was an automatic, carbed non turbo and we made it an EFI, turbo 5 speed. 1L 3cyl TI Blasted and decked block .020" off the head and new valves (OEM cam for now) Fully ported and polished head, intake, turbo, mani. Full SS 2.25” mandrel bent exhaust No muffler and high flow cat Balanced rods/OEM pistons, polished rods and minor crank touch up. Oversized radiator High flow injectors Fuel regulator inline 45psi fuel pump Anti lag controller K&N filter and cold air intake boost controler Stock turbo @ stock 15 and 22psi Ractive gauges (boost, oil, water temp, A/F meter) 4th injector injector wired up at 15-16psi Accel high power ignition, coil, wires NGK plugs (indexed) I/C ram air ACT 2600 clutch Guess what... it runs on Synthetics
The early bird gets the worm, but the second mouse gets the cheese. |
#21 | |
What the...?
Drives: '06 Blazing Blue 3 door RS. Join Date: Oct 2006
one step further with the build though, bored to 75mm with a CR that is about 8.2:1 on 10 psi from a chrysler le barron turbo run through a FMIC. and guess what it runs on 15w40 regular plain jane oil. no matter what you run, you have think what you are running from. sludge? ok then run a high detergent oil and change your filter half way between oil changes... |
#22 |
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
The sludge I'm afraid of comes from Dino oil itself breaking down quickly, from normal engine heat. I have seen the results of Pennzoil and Quacker State. Dirty crusty heads, an overall amber film over the lifters and cam. This comes from dino baking onto surfaces, and turning black and waxy in the corners of your valve covers. No Way Jose', not for me. I have been using synthetics for about 15 years now, and it's funny how I've never had a single engine malfunction from any hardware lubricated with synthetic oil. And when looking in the oil filler hole, it is shiny like new. But I have friends, oh yes, that don't believe in synthetics. Their engines are quite dirty and run like crap. If everyone used synthetics, mechanics would not be quite so rich! hehe You are in Alberta, and you don't use synthetics? What about when dino thickens up in the cold, and the first second of cranking you get metal on metal and OUCH! That hurts! Think of thickened oil being filtered. The filter gets its pores clogged quicker with waxy crap and hello bypass valve, and dirty oil coating your engine. Real Nice! You are like an old school mechanic... "I don't wants no FAKE OIL! I wants REAL OIL!"
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
#23 |
HardlyDangerous
That again is where you are wrong firefly.
Sludge is not a problem with an oil that contains no mineral oil. There are no mineral oil by products to break down. you can literally run thousands of miles and have no sludge, carbon or by product depostis in your engine. That's why companies like Amsoil and Redline recommend and oil flush before switching to their oils after running conventional oil. Because introducting a ester or poa based synthetic will clean away sludge and can clog up the oil filter prematurely and then you basically running on unfiltered oil. Using an engine flush will remove most of the sludge and deposits first then you have no problems with filters plugging up prematurely. I'm still amazed after 10+ years of using synthetic at some of the engine I have pulled apart that were running synthetic. Heck I even posted pics on here a while ago comparing conventional and Amsoil on well used engines. What you are eliminating is friction and heat and lots of it. In a turbo charged car you need the best oil you can get. Try 400,000km on a stock turbo running 20psi... that's what my sunbirt GT runs. Compression is still within' 5psi of stock, does not use ANY oil between oil changes. With less heat and friction you gain more HP and better mileage. A dyno will not lie, test your car before and after. test your car then swap the engine oil with Amsoil 2000 20w-50 racing oil Amsoil 75w-90 in the trans and re-test it. You will not only see lower EGT, oil temps but higher HP numbers. OR do some independent lab testing send in a sample of your conventional oil after 500miles and a sample of Amsoil after 5000 miles and see what one comes out on top. Sure it's easy to say I have never had a problem running this or that oil but group IV and V lubricants are FAR better then any conventional oil. Aircraft and tractor trialers often run these because the oils last 500,000km or more with bypass filtering set ups. NO conventional oil will withstand that kind of punishment. On royal purples web site you can view the before and after videos of cars tested on the dyno from shows like Hot rod TV and horsepower TV etc. If you think a conventional oil is good, MAN a true synthetic like redline or Amsoil will amaze you. don't talk to the dealers that will try to push house brand oils or have you come in for service Better yet walk around the pits of you local race tracks both street and off road bike and ATVs and see what the professional engine builders and racers are using. They use them because they are the best When I worked and Raced for both Yamaha and Arctic cat we had several oil sponsers but used Amsoil because it was what allowed us to run year after year with no DNF's and save us thousands of dollars every month because there was no need to rebuild the engines. As i said before I'm a motorcycle /ATV mechainc, that's what I do. even though I do sell Amsoil I do use it in my shop. for the people that want a cheaper oil I use mobil 1 or shell. Synthetic have save me and my customer thousands of $$$ over the years in repair costs. A DNF can make or break a championship and I have never had anengine failure since running synthetic. I've almosy eliminated any gearbox wear, extend clutch like 3X and engine wear has also be greatly reduced.
#24 |
What the...?
can you please look back at any of my posts in this thread and see if at any time i said, synthetic oil is bad?
never did i say that, all i said was that its not the greatest for a NEW car. sure once you have it broken in, do what you like. i have used and still use syn oil in other projects. just not on a brand new car that is on its 2nd or 3rd oil change. that is all i ever really said. but you guys seem to think that i was attacking the use of it all together. |
#25 |
HardlyDangerous
pretty much if ...
"using it in a new car is ghey !" you claim it will somehow damage the valve guides and seals you have to wait 4 years or 100,000km takes 20,000 to break in an engine. I agree and will always stand by the fact that an engine/any engine should be run in using a group I to group III oil. NOT a group IV or V lubricant. But once the engine is run in (compression level has reached it peak) and the sooner you switch to a snythetic the sooner you start to protect the engine and start reducing friction and heat. Anytime after the first oil change is perfect. It will NEVER take 20,000km for compression to reach it's peak. Infact most most can be run in in less then an hour. I just waited the until my first oil change to swap in the synthetic. What kind of oil do you use because the dollar stores sells the ecaxt same oil you buy from canadian tire for $1 liter. sometimes 2 for a $1
#26 |
What the...?
i'm getting free oil changes for the next 4 years from the dealer only because i asked for them when i bought the car and they agreed.
i buy the car, they work on it, it breaks, they fix it and i am happy. if we agree to disagree on this then it will be over and we can go about our day. you like sooner i like the longer wait. that is all. |
#27 |
![]() ![]() Drives: Yaris YRS Sedan Join Date: Sep 2006
Hi all,
Wow, this really is a hot topic. I've switched to fully synthetic Castrol Edge Sport 5w-30 after 2400km's along with a puralator pure one filter. I believe that engine's should be run in with dino oil. The engine should be run in correctly, varying rpm's and loads, moving up to higher rpms and loads as kilometers build. Many have said modern engines run in in approximately the first 500kms( piston rings, seals, cylinder walls... the important stuff). So I thought I'd make sure by letting it run in for 2400kms. The valve train (cams, guides etc) won't run in in this time, but tolerances are so good these days that it's not necessary I believe. One thing I noticed was that fuel efficiency has increased noticeably using synthetic. So that means friction has been reduced and efficiency increased. If I get glazed bores, smoking, blow by etc... you's will be the first to know about it. Thanks all:) |
#28 |
![]() ![]() ![]() Drives: two yaris liftbacks Join Date: Jan 2006
I've been using mobil 1 on all my vehicle for 12 years. Its all they've known. And as my mechanic has said my engines are like brand new inside.
I switched to amsoil with my yaris after reading that it is a step up from mobil 1. I did run the yaris for the first 3000 miles on whatever toyota put in it to begin with. |
#29 |
![]() Drives: yaris sedan 07 BLACK Join Date: Aug 2006
Well, Guys, as far as our Yaris has only 180 miles on the odometer, I'll wait with Amsoil for a while, but already have found the local dealer, here, in Milwaukee, so my other car, 4runner, is definitely getting engine flush and Amsoil with a next oil change... thanks a lot for a very valuable inputs and hot discussion
#30 |
Engineer/Artist/House-Dad
Drives: 2006 Toyota Sienna XLE Join Date: Aug 2006
recently found bonus of changing to amsoil: my engine is running MUCH smoother and efficiently. case in point, i used to travel at 65mph @ 2000rpm. i now travel @ 71mph @ 2000rpm. you either take it as a bump in power (more speed at same rev) or a bump in fuel efficiency (less rev needed for same speed). either way, i am ridiculously happy. i'll update the fuel efficiency after a few fill-ups.
--B ps: this is for my sienna. i LOVE that V6...
His: 2006 Toyota Sienna XLE Arctic Frost Pearl, FC Package, 2007 Solara Nav unit, Spoiler, Running Boards & Auto-dimming rear mirror Hers: 2007 Toyota Yaris LB Black Sand Pearl, Auto, Power Package, Side Airbags, VIP security, USDM center armrest, and accessory 7 spoke 15" alloy wheels |
#31 |
HardlyDangerous
Besides the power you gain and fuel you save you can save a LOT of $$$ using amsoil.
With Amsoil 2000 0w-30 and Amsoil filter it's good for 35,000 miles or one year figure that out compared to how many regular oil changes you will do at 500mile intervals plus filters etc you save $$$ using Amsoil in most cases unless you are running the cheapest conventional oils out there. lets use my truck (99 chevy Xtreme) as an example. Before I sold it, I put 100,000km on it in three years 5L of Amsoil X $9.70 plus filter at 16.45 =$65 Mobil 1 at $ 6 and purolator filter at $5 = $35 good regular conventional oil at $3 and filter $5 $ 20 Mobil 1 and conventional oil recommend 5000km oil changes that 20 oil changes over 3 years Amsoil recommends I year oil changes or every 35,000 miles (what ever comes first) Amsoil ($65 x 3) = $195 Mobil1 ($ 35 x 20) = $700 Regular conventional oil ($20 X20) = $400 Even if you are like me and change your Amsoil every 6 months that still only $390. It's still cheaper then using mobil1 or most conventional oils and a group IV or V synthetic will protect your engine and free up more HP MUCH better then any conventional or even group III oil. Now just think how much money I have saved in my laser with 300,000km on the odometer. 7 oil changes. And after 300,000km the compression is still perfect, does not use more then a liter of oil between changes, no dreaded DSM lifter tic, and no dreaded auto trans O/D clutch slip. That would have been 60 oil changes using regular oil or Mobil 1. That's $455 with Amsoil vs $2100 with Mobil 1 I don't know about you guys but I would rather save my $$$ then give it to big huge oil companies that rip us off fuel fuel prices as well.
#32 | |
HardlyDangerous
Most car dealers in Canada buy oil in bulk below wholesale from Shell or Esso and it cost the dealers next to nothing. Less then a dollar a liter for 55 gallons (210 liters) and they usually charge $20 a gallon or more for it. With that kind of money rolling in the door they don't care about free oil changes to some customers, or doing some promotions They will recommned the cheap stuff to customers because that's where they make the big money. Some do supply more costly synthetics. My local GM and toyota dealers gives the first couple changes for free and every 5th oil change free after that. Both use Shell oil and Mobil 1 on request. Be careful with the free oil changes too. There is serects to making $$$ on them like many crooked quick lube centers out there. They remove the oil filter, clean it well, and re-install it. Some even go as far insert machine screw to open up the anti drain back and flush the filter out a bit with solvents. But most will just wipe them with an armorall soaked rag to give it that shiny gloss new look if they don't have any paint chips or scratches on them. So it costs them like $3 every time you want an oil change and thay makes HUGE proffits. Even if they do use OEM filters it only 1-2 bucks max for wholesale filters. I used to buy filters at wholesale from Hiflofiltro, the supplier for Honda , Yamaha and many other OEM motorcycle filters. The Dealers charge as much as $15 per filter. Wholesale I was payin less then $3
#33 |
What the...?
yes, i am happy. this has given anyone without any knowledge in regards to oil choices to make an informed desicion. that is the whole idea behind a message board...
needless to say i still think that both of us are right and that our opinions that we DON'T share are both with merrit. its been heated... both of us think the other is still suffering the loss of nearly half a brain, and its been entertaining... |
#34 | |
![]() Drives: 2007 Yaris Sedan Join Date: Mar 2006
#35 |
![]() ![]() Drives: 2007 Yaris Liftback Join Date: Sep 2006
Well.... As long as we are all here and talking about oil changes.. Anyone got part numbers for non-genuine Toyota Filters?
Fram (these suck) Amsol Purolator AC What ever else is easily available?? Also.. Do you guys change the oil plug gasket? My Yaris is still new and I usually change the oil at 2000 - 2500 miles when new but for now, I haven't had it apart so I don't know what type of gasket it is. GM uses a rubber o-ring in an aluminum washer. Honda uses an aluminum crush washer. Pretty hard to get off the plug if you over-tightened the plug on the last oil change. |
#36 |
What the...?
i just did a quick search, here is what i found for oil filters
penzoil filter PZ39 mobil1 filter M1103 K & N filter HP1003 |
| LB M/T options | Howard2621 | New YARIS Purchase Forum | 1 | 09-22-2006 11:37 PM |
