Old 05-29-2009, 01:14 PM   #73
2009Toyotoad
Drives: 2009 Yaris 3dr
Originally Posted by borezack View Post
Hello first post here.
I have an 08 sedan.
Just would like to know if I should change from using 85 to 87.
I'm driving at 3000 to 10000 ft elevation and regular here is 85, plus is 87 and premium 91.
Also Just took a trip and was about 200ft above sea level and I used 87 since that was regular and my car felt like a rocket ship lol
Just would like some input.
Thanks
This is probably a question best answered by a local Toyota dealer. They should have the best knowledge on local conditions and fuel qualities.
2009Toyotoad is offline   Reply With Quote
Old 05-29-2009, 01:30 PM   #74
borezack
Drives: 08 Yaris Sedan
There is no local Toyota dealer here. The closest one is over 130 miles away.
Will 85 octane damage the engine?
borezack is offline   Reply With Quote
Old 05-29-2009, 01:45 PM   #75
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
87 octane is the lowest recommended isn't it? I wouldn't go lower than that, esp. at higher altitudes.
Old 05-29-2009, 03:23 PM   #76
twowheels
Drives: '09 Meteorite Metallic 3 dr MT
Originally Posted by Aothachos View Post
+2 lol i used to get 60 miles before the first bar went, now i use 91 it goes up to 75-80 on the first bar =), i wasn't satisfied with 60 miles on the first bar
I'll call your anecdote and raise you one...
I always run 87 and almost always get 90+ miles from the first bar w/o topping off.
twowheels is offline   Reply With Quote
Old 05-29-2009, 08:21 PM   #77
mryaris
Drives: 2010 Carmine Red hatchback
No. 85 octane is used in locations with high altitudes because it behaves like 87 does at lower altitudes/sea level. I live in Colorado and regular is 85, mid is 87 and premium is 91.
So.....to clarify a bit, high altitude 85 octane= the 87 octane that all the low-landers use, so using mid-grade 87 is not necessary.
mryaris is offline   Reply With Quote
Old 05-30-2009, 01:04 AM   #78
SilverGlow
Drives: 2007 Yaris Hatchback
As the altitude goes up, the requirement for high octane goes down.
SilverGlow is offline   Reply With Quote
Old 05-30-2009, 07:17 AM   #79
Forrest
Drives: 08 LB BLACK
With the cost of gas going up so quickly, yesterday, May 29th it was 2.60 for 87 and 3.00 for highest oct., I would stick to the recommended gas at the lower price.
Forrest is offline   Reply With Quote
Old 05-30-2009, 08:27 AM   #80
ImportRacer88
ImportRacer88's Avatar
Drives: 4dr Sedan s
Send a message via AIM to ImportRacer88 Send a message via Yahoo to ImportRacer88
when i first got mine i ran preimum once and the car ran like shittocky mushrooms and when i went to fill up i put regular back in it and it ran better so i just been running reg had no probs here but im moving back to pa has ne one had any probs woth thier CAI in the snow pm me and let me know
ImportRacer88 is offline   Reply With Quote
Old 05-30-2009, 08:27 AM   #81
borezack
OK thanks for the info
Old 05-30-2009, 01:42 PM   #82
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
How far you go on the first bar depends heavily on how full you fill the tank. I run the pump fast till it clicks off, wait a few seconds, start it back at a trickle and let it click off again. (It barely puts in a dollop of gas the second time, but it makes for a pretty consistent fill without overfilling.) I usually get close to 100 miles on the first bar.
Old 05-31-2009, 06:19 PM   #83
voodoo22
Drives: Yaris Sedan (auto)
We've never put in anything other than 87 octane. We purchased the Yaris to reduce travel expenses and given it's performance over the first 79 fill ups 87 octane suits it quite well.
We do only fill at top tier stations though.
voodoo22 is offline   Reply With Quote
Old 07-01-2010, 04:15 AM   #84
Thai_Dang
Thai_Dang's Avatar
Drives: 2010 Yaris 5-Door LB AT MM
91 octane will make your penis larger. yeah i've also read anything above 87 is harmful for your engine. Makes sense, these cars have sensitive timings. But i can't imagine with how many computer chips they put into these cars nowadays, that the ECU would detect the 91 octane that some idiot put in their car and adjusted the timings of fuel injection so it doesn't cause engine knock/build-up.
Thai_Dang is offline   Reply With Quote
Old 07-01-2010, 06:03 AM   #85
ddongbap
HOLY THREAD REVIVAL.
Old 07-12-2010, 08:51 PM   #86
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Compression dictates octane
frog13 is offline   Reply With Quote
Old 07-12-2010, 09:01 PM   #87
yarrr
Drives: 07 sedan
ya its kind of his thing if you hadn't noticed. I think maybe his "new posts" button reads "old posts" and he can only see the oldest posts on the forum.
yarrr is offline   Reply With Quote
Old 03-21-2011, 08:54 PM   #88
10peep
10peep's Avatar
Drives: 2010 3D LB 5spd
I just spent 35 minutes reading this pissing contest so I absolutely HAVE to make some kind of comment to revive it. You ready....? Here it is.........comment.
Originally Posted by 07WYarisRS View Post
"......Thats why many bio deisel set up have a deisel start because the biomixtures like used engine oil of veggie oil often has a much higher flashpoint and is harder for the engines to start on them. they start on the diesel and then switch over to run on bio once warmed up......."
^^^ This is wrong, btw. Biodiesel setups usually do not have any type of diesel start or diesel purge setup because biodiesel is made by the user from WVO. On the contrary, WMO/WVO setups almost always have a diesel start and diesel purge setup because the viscosity of the "fuel" (WMO/WVO) is MUCH higher than the viscosity of ordinary diesel until it reaches temperature (usually around 180deg) and will very quickly clog up one's entire fuel system if initiated before it reaches optimum temp. Consider this thread revived and maybe now we can discuss something MUCH cooler than octane ratings, smoothness and high/low compression engines....DIESEL!!!!
10peep is offline   Reply With Quote
Old 03-21-2011, 10:23 PM   #89
Idahotom
Drives: 2008 5 sp. LB
Speaking of diesel: I was at a gas station in SE Idaho the other day, fueling up my 22 ton boom truck. I was astonded to see they were offering straight diesel ($3.86 per gallon), off road/non dyed (and you do NOT want to get caught with that in your tank) for $3.64, and lastly bio diesel for $3.86. The owner of the station must be a diesel freak! As everywhere else was elling diesel for $3.97 or higher, I was a happy camper.
A few days earlier, while also fueling the boom truck, I struck up a conversation with a VW Jetta driver: 47 to 49 MPG, and he had over, well over, 200,000 miles on it. Without even doing the math (in general higher priced diesel V. gasoline) the Yaris compares well...( in the low 40's, my own results) plus I trust Toyota more then VW!
Idahotom is offline   Reply With Quote
Old 03-22-2011, 08:25 PM   #90
10peep
10peep's Avatar
NICE!!! Yeah, its hard to even FIND off road Diesel here in VA, much less without any dye in it. Its SO funny you mention a VW diesel... I was ON MY WAY to the stealership to BUY a VW diesel that I had ALREADY test driven a couple days earlier but I had read SO many bad things about EVERYTHING other than the motors on these cars that I just didnt feel comfortable doing it. I figured that Id swing by the local Carmax to see what they had first walked right PAST the Yaris that I actually ended up going back and buying 4 days later. Went across the street to the VW, Subaru place and some guy came in with a diesel Jetta and couldnt say enough about how much of a turd it was and thats all it took for me. Went across the street to the Toyota joint, test drove a new Yaris (on my wife's suggestion, because she saw the one at Carmax ), went back to Carmax and bought mine for $5k off of sticker with 12k miles on it.
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 02:35 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
