Old 05-31-2009, 05:47 AM   #1
fuji
fuji's Avatar
Drives: Polar White Yaris HB
1ZZ throttle - Not Optimized Yet!
Well, just finished the 1ZZ install without a hitch. No cel! The problem I saw when I installed the throttle body was the manifold has a opening which is too small and restricts the airflow. To really take advantage of the new throttle body, I think we need a newly designed intake manifold. Any thoughts??
In addition, what intake system are people using with the new throttle body? Perhaps something designed for the 1.8 liter TS or even a Matrix intake?
fuji is offline   Reply With Quote
Old 05-31-2009, 10:30 AM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
yah someone had a prototype but i guess decided to cancel the project..*sigh* too bad.. 15-20 hp increase for under $700 sounds very reasonable.
Old 05-31-2009, 10:56 AM   #3
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
^yeah, but garm is picking it back up
To the OP, if you feel comfortable, you can port match the intake manifold, it just wont fit the stock TB with its gasket after you do this
Old 05-31-2009, 12:17 PM   #4
It's picked up. DynaTek is interested, and I already have a backup fabricator if they fail to come through again. However, the intake manifold project was based on using a stock throttle body. If we limit it to throttle body swaps, it might mean not enough sales to do the manifolds. And I'm not doing a bunch of versions, so let that be known.
Old 05-31-2009, 12:58 PM   #5
fuji
fuji's Avatar
As long as the new intake manifold is made out of metal and it is thick enough, it can be bored out. This will avoid the strange 90 degree lip where the throttle body connects to the intake manifold. Even more gains!
As long as there is a will, we will find a way!
Old 05-31-2009, 01:46 PM   #6
06silveryaris
Drives: 2006 yaris
i haven't looked at the manifold entrance but can't the plastic one be bored out?
06silveryaris is offline   Reply With Quote
Old 05-31-2009, 05:01 PM   #7
gwasabi
Drives: 07 Blazing Blue LB
I'm pretty sure the plastic one can be bored out. Use a dremel tool or something. I was actually thinking of doing this soon but i messed up my manifold so i'm looking for a stock manifold to buy. hahaha
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-31-2009, 06:18 PM   #8
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
About nine years ago, I had a Ford Focus and bought a larger throttle body for it. I port matched the intake manifold, and it was made out of plastic. I just stuffed a rag down into the manifold and used a Dremel and a vacuum to suck out the bits. Worked very well. I'd try the 1ZZ-FE TB, but would make sure to bore out the manifold. Otherwise, it's just bottle necking the airflow.
Old 05-31-2009, 06:29 PM   #9
frownonfun
frownonfun's Avatar
so stick with the stock throttle body is what you are saying? if we are interested in this manifold that is?
Old 05-31-2009, 06:59 PM   #10
People who have done the throttle body mod report more power. Port matching would do even more.
Frown, I'm not saying I won't do it, but it will be dependent on interest, how many people want to go the whole way with intake mani + larger TB.
Old 05-31-2009, 07:25 PM   #11
DJPaneno
Drives: 07 Yaris Sedan
I would be interested, already planning on swapping the throttle body as my next project. I don't know how much something like an intake manifold costs, but it sounds useful.
DJPaneno is offline   Reply With Quote
Old 05-31-2009, 08:42 PM   #12
Thirty-Nine
Yeah, well the "butt dyno"is a bit subjective until a real dyno run is done. Throttle response is one thing ...
Old 05-31-2009, 09:49 PM   #13
yarstar
Drives: 2008 Absolute Red HB
I've swapped mine, Garm, but I'll go with whatever you produce and mod it if necessary.
Thanks for picking the ball back up on this. I think it will make significant gains.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 05-31-2009, 10:08 PM   #14
The butt dyno IS subjective, that is true. But when someone like Jkuchta, whose racing and technical expertise surpasses my own, says it makes a difference, I'll take that as being true.
Old 05-31-2009, 10:18 PM   #15
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
has no one heard of the venturi effect?
http://en.wikipedia.org/wiki/Venturi_effect
Old 05-31-2009, 10:56 PM   #16
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Hey Garm, when can we expect to see the production pieces done assuming DynaTek does pick up the production for the intake? I'm not sure you mentioned this in the intake thread. I'll take whatever you make!!
Galavoxx is offline   Reply With Quote
Old 05-31-2009, 11:01 PM   #17
I'm not sure, but I'm having a phone conversation with DynaTek again tomorrow.
Old 06-01-2009, 02:05 AM   #18
fuji
fuji's Avatar
An improved intake WITH the 1zz throttle body is going to make some awesome gains! I CANT WAIT!
1ZZ Throttle Body Spacer tk-421 Performance Modifications 34 07-11-2017 10:48 PM
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 08:57 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 09:52 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 01:03 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
