Old 06-11-2009, 12:33 PM   #1
fuji
fuji's Avatar
Drives: Polar White Yaris HB
Intake for the 1ZZ throttle body?
I am very pleased with the butt dyno performance of the 1zz throttle body. When I put on the Bomz intake, I noticed the tubing is slightly smaller than the diameter of the throttle body itself.
Would there be a benefit to have a custom diameter intake? It would probably be easy to make. The other option is to find another vehicle such as the TS or a Matrix/Corolla pick up a short ram intake an use it instead.
Do you think doing this would make anymore power? It could possibly really make a difference with a different intake manifold.
fuji is offline   Reply With Quote
Old 06-11-2009, 02:15 PM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
You need to look at the inside diameter. I don't think a slight difference would affect performance. If anything the MAF sticking out in the middle of airflow creates more restriction.
Old 06-11-2009, 02:55 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
i wouldn't recommend a larger diameter intake tube either. wreaks havoc on the ECU if you don't compensate for it.
Old 06-12-2009, 07:51 AM   #4
agreed....i tried my intake from my matrix, which was 2.5", and it was incompatible w/ my yaris
Old 06-12-2009, 06:03 PM   #5
fuji
fuji's Avatar
Wow, so the consensus is there would be no benefit in increaseing the diameter of an intake piping to match the throttle body?
Old 06-12-2009, 06:07 PM   #6
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I think there would be a much higher improvement by port matching the intake mani to the new TB diameter. Even then the change wouldn't be drastic.
Old 06-13-2009, 02:44 PM   #7
i got a CEL for running lean....
Old 06-13-2009, 03:47 PM   #8
EdgarTRD1.8
Drives: SR5 Hatch Back 82' 3TC 1.8
Send a message via MSN to EdgarTRD1.8
I'm building a 1nz-fe Aluminum Intake Manifold with 1zz-fe Throttle Body. The Intake is like this on the 3TC but is littler than this one and has an inclination. I'll take some pics to post step by step the process. Only I need is the 1zz TB to drill the spacer to bolt it and weld, a friend has one but he doesn't bring it to me yet.
EdgarTRD1.8 is offline   Reply With Quote
Old 06-13-2009, 07:54 PM   #9
bladesmith6
Drives: 2007 yaris HB
Tried a larger diameter tube threw a code right away, the sensor is very touchy.
bladesmith6 is offline   Reply With Quote
Old 06-14-2009, 12:02 AM   #10
yaris-me
Learn to Relax
Yes. Unless you have this:
http://www.yarisworld.com/forums/showthread.php?t=11971
Then you need to port and polish, and match intake openings.
1ZZ Throttle Body Spacer tk-421 Performance Modifications 34 07-11-2017 09:48 PM
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
intake and throttle body Q thebarber Performance Modifications 3 08-20-2007 07:02 PM
