![]() Drives: Echo 2002 Hatch Join Date: Jun 2009
australian vs american models: timing chain
Hi all,
I am wondering whether there'd be any difference in the engines between the Aussie and US versions of the 2002 Echo? Specifically, information for the US model says it uses a timing chain. Surely the aussie version would also have a timing chain (and not a belt)? any info gratefully taken cheers christian |
if it has the same engine, it will have the same timing chain
My 01 and 05 Echo's have a 1.5l motor and both have timing chains.
if you have the 1.5L 1nz-fe engine, yes timing chain.
others... well, i guess the 1.0L and 1.3L owners can tell us longer. |
| yaris timing belt | phenoyz | General Yaris / Vitz Discussion | 16 | 02-24-2015 01:05 AM |
| wtf?! timing chain cover split?! | jeff69dini | DIY / Maintenance / Service | 9 | 08-01-2007 12:11 PM |
| Does the Yaris' engine have a timing chain or belt? | grampi | General Yaris / Vitz Discussion | 8 | 05-12-2007 03:59 AM |
| Timing chain, sprockets, & cam position sensor problems? | PetersRedYaris | DIY / Maintenance / Service | 8 | 01-04-2007 11:50 AM |
