Old 06-22-2009, 01:40 AM   #1
RedRide
RedRide's Avatar
What filament does the DL running light use?
Since the Yaris use a double filament headlight bulb, (a single bulb for both low and hight beam) I'm curious about which filement the DLRL uses.
Old 06-22-2009, 01:44 AM   #2
silver_echo
ekodrvr
silver_echo's Avatar
i will look on the EWD and make sure but i am 95% sure that it uses the high filament... give me a couple minutes...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 06-22-2009, 08:11 AM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
uses low beam in Canada. Pretty sure it is the same in the States.
Old 06-22-2009, 12:33 PM   #4
RedRide
RedRide's Avatar
Most cars use the high beam at lower voltage for DLRL.
I assume that the Yaris does the same but, i just wanted a definitive answer.
I guess I will still have to wait on this.
Old 06-22-2009, 01:00 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
1. walk out to your vehicle.
2. turn on vehicle.
3. look to see which filament is lit ;)
heheeh sorry man, it just appeared to be the most definitive solution.
Old 06-22-2009, 01:11 PM   #6
Sandwash
Drives: 2009 Yaris w/man.trans.
On my 2009 daytime running ligts use a separate smaller bulb located apart from the primary bulb - very clever and efficient set-up. Or am is not getting the question?
Sandwash is offline   Reply With Quote
Old 06-22-2009, 01:14 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
i think you're referring to the 'city light' the 194 bulb.
Old 06-22-2009, 01:36 PM   #8
RedRide
RedRide's Avatar
2. turn on vehicle.
Not really. The view of the headlight bulb is obscured by some sort of decroativ/reflective shield.
Old 06-22-2009, 01:59 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
try removing the bulb on the passenger side?
Old 06-22-2009, 02:48 PM   #10
From the 09 service manual:
(2) The Running light relay assembly controls the on/off operation of the following part.
• Headlight (Low)
Old 06-23-2009, 01:29 AM   #11
RedRide
RedRide's Avatar
Thanks
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
Day time Running light....how to disable? Polar_Yaris DIY / Maintenance / Service 33 01-27-2009 06:02 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
