Old 06-24-2009, 09:09 AM   #1
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Water in Spare Tire Well
Anyone else have this problem?
This is the first problem with my 2007 liftback with nearly 90,000 miles.
I haven't done anything recently so I don't have a clue what caused it.
I noticed a musty smell in the car and thought one of my kids left something nasty in there.
Upon investigation, I found several inches of water in the spare tire well. I pulled the drain plug, dried it out and replaced the plug. The water was back after the next rain.
I'm now driving around with the plug out, but want to fix it right.
The weather strip around the hatch looks fine.
Any ideas?
Old 06-24-2009, 10:29 AM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
You've got a leak for sure. It may be hard to find. My 2007 sedan (now my daughter's) did this after a rear end collision was fixed, so the body shop guys worked on it 3 times before finally getting it fixed. One would get inside the trunk while another sprayed a hose around, till they found where the water was coming in. There are places you could get a leak around the sides, not just around the hatch.
Old 06-24-2009, 01:07 PM   #3
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Yup, and that is the ONLY way to find a leak like that; I was trunk monkey 50 years ago, some things never change!
Old 06-24-2009, 01:21 PM   #4
kurokoma-kun
Drives: 2007 Yaris HB
Do you have aftermarket taillights? One of mine leaked and drained into the hatch too, sealing the edge of the light fixed it.
Old 06-24-2009, 01:27 PM   #5
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
could be around your tail lights. do you have stock taillights?
Originally Posted by xnamerxx
you nailed it sir.
Old 06-24-2009, 01:27 PM   #6
Tamago
Tamago's Avatar
Drives: ZZW30
ah crap you beat me
you nailed it sir.
Old 06-24-2009, 02:40 PM   #7
silver_echo
ekodrvr
silver_echo's Avatar
this has happened to others... here is a link to the thread on the echo forum...
http://echodrivers.com/forum/viewtopic.php?f=2&t=14911
not sure how to fix it, but i thought this info might help you...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 06-24-2009, 03:17 PM   #8
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
I've had a lot of old cars and water usually leaks from the window seals. The seals are exposed and with long exposure to the sun they dry and get brittle and have leaks that are hard to detect. Hope this helps.
Old 06-25-2009, 08:57 AM   #9
Violin
Violin's Avatar
Thanks folks. You've given me a lot to work with.
My tail lights aren't stock. They're authentic Vitz LED models from Toyota Japan but they might be the source.
I guess I'll need a helper and a hose.
Thanks!
Old 04-02-2012, 11:00 PM   #10
Unicron
Unicron's Avatar
Drives: Bayou Blue HB 07
I am getting a musty smell in my car now that it is getting warm out, I bought my car used in the winter. I noticed the other day while installing an amplifier that there was water underneath the plastic tray to the right of the spare tire. Suspecting it maybe the tail light, I took it out and could see there has been water leaking in through the gasket for a while. I took a pic.
Despite this thread being dead for 3 years... I think this shows the problem pretty clearly
Unicron is offline   Reply With Quote
Old 01-30-2015, 06:22 AM   #11
El Kapitan
Senior Veteran
Drives: 2007 5 door hatchback
i had the exact same problem in the exact same place.
El Kapitan is offline   Reply With Quote
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 03:00 PM
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 07:29 AM
The thread with the single, hidden sub over spare tire? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 43 07-17-2009 02:21 AM
Tire Wear Analysis Loren Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 06-13-2009 10:28 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
