Old 06-24-2009, 10:50 AM   #1
Lawrence Berk
Drives: 2007 Yaris LE
Tire rotation?
Hey!
Just a quick question regarding some tire maintenance.
How often would you more experienced folk recommend tire rotation/alignment??
Thanks
Lawrence Berk is offline   Reply With Quote
Old 06-24-2009, 10:52 AM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
what does your owners manual say? ;)
Originally Posted by xnamerxx
you nailed it sir.
Old 06-24-2009, 10:52 AM   #3
MadMax
MadMax's Avatar
I got the lifetime coverage from Discount Tire and get my tires rotated and balanced every 5000 miles (to coincide with oil changes).
I don't worry about the alignment too much, but will get one done when I (eventually) get some DF210s installed.
Cheers! M2
Old 06-24-2009, 11:46 AM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
I never rotate my tyres, but I regularly check tyre pressure and wear.
Old 06-24-2009, 12:15 PM   #5
Tamago
Tamago's Avatar
Drives: ZZW30
every time i drive, i rotate my tires. usually only in one direction, but sometimes in parking lots they get rotated the OTHER direction too
you nailed it sir.
Old 06-24-2009, 12:27 PM   #6
SpaceShot
SpaceShot's Avatar
Drives: 2008 Yaris 5 speed HB
Where I am I run a full set of snows from Dec 1 to Apr 1. They are mounted and balanced and sitting in the garage under the bench.
When I change over for the seasons, some simple chalk marks (on the inside sidewall, near the rim) indicate which location that tire came from, and at the following change over I try to remember to not put them back at the same location on the car.
For me it's roughly 16K miles on the all season tires between change overs. (and rotation)
SpaceShot is offline   Reply With Quote
Old 06-24-2009, 01:16 PM   #7
silver_echo
ekodrvr
silver_echo's Avatar
i would usually recommend approx 6000 miles between tire rotations, however, if at 6000 miles you cannot tell a difference in the tires, then i might be persuaded to run a 12000 mile interval... remember, rotation of your tires is to help your tires last longer...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 06-24-2009, 02:10 PM   #8
kimona
kimona's Avatar
I love this answer!
Old 06-24-2009, 02:13 PM   #9
kimona
kimona's Avatar
Rotating won't "help your tires last longer..." Rotating simply allows for more uniform wear of all four tyres.
Old 06-24-2009, 02:55 PM   #10
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
I rotate mine every 3000-5000 miles. It only takes 10 minutes or so with a proper jack/tools. Why not?
Old 06-24-2009, 03:02 PM   #11
silver_echo
ekodrvr
and with uniform wear, tires will last longer...
Old 06-24-2009, 03:02 PM   #12
markitect
Drives: Yaris
If it is a leased car, you plan on switching to a new tire when they wear out or you plan to sell it during the life of your tires, make sure to rotate them. If you plan on keeping your yaris (which I'm sure most of us do) I really wouldn't bother. You can rotate it and buy 4 new tires at about the same time, or you can not rotate it and get 2 at a time.
If you don't plan on rotating them make sure to look at the tire wear periodically. Uneven wear can be a sign of a major problem, or that you need to get your alignment checked.
markitect is offline   Reply With Quote
Old 06-24-2009, 04:31 PM   #13
kimona
kimona's Avatar
Most people believe this, but it is absolutely not true.
Tyre rotation allows for uniform wear of all four tyres... which simply means all four tyres wear out at about the same time. This does not equal longer tread life overall.
Old 06-24-2009, 04:37 PM   #14
Tamago
Tamago's Avatar
Drives: ZZW30
it depends on your alignment setup.. but for the most part i agree with you.
you nailed it sir.
Old 06-24-2009, 07:03 PM   #15
Kal-El
Kal-El's Avatar
It's really not necessary to rotate more than every 10,000 miles even though many shops recommend 5,000. That's just overkill.
Old 06-24-2009, 08:47 PM   #16
supmet
Drives: 2007 4 Door Yaris
First off, I've seen this isn't true from personal experience. Tamago is correct with it having to do a LOT with alignment set up. But with the stock setup, generally the front tires will wear more on one side than on the other. As this wear increases, the rate of wear increases because the uneven tire will take more force(damage) on the side its now leaning towards - also, the tire is engineered to have a flat contact patch. Rotating these tires to the back tends to flatten them out creating an even contact patch, slowing the overall wear.
And +1 about free rotation and balancing at discount tire. BOTH of which will increase your tire life. Throw in road hazard and its a no brainer.
Old 06-24-2009, 09:27 PM   #17
Kal-El
Kal-El's Avatar
Town Fair Tire (Northeast tire chain) does free rotations every 5,000 miles for life with any 4 tire purchase.
They also do:
Free front alignment,
Free mounting, balancing,
Free tire repair for life,
and guaranteed lowest price
with any set of tires
Very hard to beat.
Tags
rotation, tires
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
Tire Rotation captainm27 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 11-04-2008 01:01 PM
Do the tire rotation myself. hans_fh General Yaris / Vitz Discussion 6 06-06-2007 10:01 PM
10 Bucks for Tire Rotation hans_fh General Yaris / Vitz Discussion 11 06-05-2007 10:38 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
