Rides canyon walls
Drives: 1988 RX7 FC 10th AE Join Date: Jun 2007
New brake pads and noise
So I got some carbotech pads and this is my first brake pad change I've attempted. Before I changed the pads I was getting some squealing noises when I was barely tapping the brakes. Regardless of the noise, I wanted different brake pads anyways. So I installed the carbotech pads and put some lube stuff on the back of the shims. Then I go out to "bed" in the brakes. I hear some squealing on my right wheel ONLY when I press down super hard. I know there is a break in period for new pads and a proper "bedding" of the pads are required. However would this same noise be related to the noise with my old pads? My old pads didnt seem very worn out and the rotor seems to be in good condition. Should I wait a while till my pads are broken in or could it be something else?
![]() OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header |
could be dirt or maybe the 'Squealers' are out of place? can you snap some pix?
Rides canyon walls
I can take pics tomorrow, I'm just getting over a fever right now and I'm super tired. Just pics of the rotor is what you need? I'll go over the pad install again tomorrow and clean a little more to see if that helps. I dont have to drive anywhere tonight so it'll be ok till tomorrow.
der Zeck
probably a bent backing plate
#5 | ||
Also it sounds like you didn't change or turn your rotors. Take them off and down to a machine shop and they'll turn them for around 20 bucks. Give those new pads a fresh surface to work with.(if you turn them now you'll probably have to rebed them, but I'd call carbotech to make sure) |
![]() ![]() Drives: 2008 Yaris HB Join Date: May 2009
The Yaris brakes suck I try not to use them.
![]() Has anyone noticed an increase in braking performance with the carbotech pads and was it just resistance to fading or initial feel and performance? |
#7 | |
Rides canyon walls
Rides canyon walls
I drove a bit and no noise till the brakes heated up and it started to squeal again. hrm..
Half a Bubble Off Plumb
You didn't reface the disks? There'll be a pretty long breakin period till the worn surfaces of the disks take on the wear pattern they get with the different pad material.
| DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads | ChinoCharles | DIY / Maintenance / Service | 40 | 10-13-2017 05:23 PM |
| CarboTech brakes in stock | cali yaris | Micro Image | 20 | 07-28-2009 04:50 PM |
| Parking Brake Adjustment Q's | Lafiro | DIY / Maintenance / Service | 3 | 04-13-2009 08:19 PM |
| ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS | kargoboy | YarisUniverse | 11 | 01-20-2009 04:43 PM |
| First thoughts: Carbotech XP8 pads and slotted rotors | jkuchta | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 37 | 12-19-2008 10:21 AM |
