![]() Drives: 2007 yaris hatch Join Date: Dec 2008
TSB 0344 update from 6-20-09
Toyota replaced my wire harness and then they replaced my throttle body all at no charge. I have 45,000 miles on my 2007 hatch. If any of you are having
trouble with the above and are out of warranty, make sure you tell dealer that Toyota knows of this problem and should make you whole!!!!!!! |
what exactly was the issue?
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
Could you post the TSB?
Please be specific.
Never take eyes off opponent - Bruce Lee |
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
found it but cannot post for some reason.
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ Last edited by ROCKLAND TOYOTA; 06-26-2009 at 02:51 PM. |
The issue was the car kept stalling (the gas pedal was just dead) I was getting a code that said trouble with the throttle position sensor but Toyota said replace the wire harness. After replacing the wire harness still had same problem so they then replaced the whole throttle body. Three days now with no problem. I told them to peplace throttle body from the start, but they first did the wire harness.
You can also read my post on 6-20-09
| Rattle TSB I found the other day. | ToyotaTEch21 | DIY / Maintenance / Service | 37 | 05-29-2018 11:17 AM |
| Dash rattle TSB needed ! | tsportman | DIY / Maintenance / Service | 15 | 07-06-2009 06:20 PM |
| TSB for flaws. | hans_fh | General Yaris / Vitz Discussion | 3 | 08-01-2007 09:38 PM |
| TSB for steering pull? | vst | DIY / Maintenance / Service | 12 | 06-09-2007 02:40 PM |
| My New Yaris (First Car), About me, and my TSB Questions | dlinkwit27 | DIY / Maintenance / Service | 1 | 06-03-2007 12:34 PM |
