visor decal removal
Debadging the the trunk lid made me happy but I am much happier now that I have removed my air bag warning decals from my sun visors!
Pics? How?
This issue of sun visor decals has been raised many times.
It has. Didn't someone black it out w/ sharpie once?
#4 | |
I know I'm bad... I should have taken pics while I was doing it, but I got caught up in the moment! I took 2" masking tape and taped close around the decal. I used "Goof Off" in the original small can that looks like lighter fluid. Saturated a clean rag with the goof off and daubed it on the decal, got it plenty wet. Did that a couple times. Then started to rub lightly in one direction as I kept the rag plenty wet and continued to use a section of the rag that was clean. The decal will start to break down and roll off in little balls. Continue until you're finished. Remove the masking tape and go over it one more time. Then I took 91% alcohol and cleaned up the area. It will leave a slightly raised and lighter area where that decal was, but in time it will blend back to where it should be. As I was rubbing the decal off - some of the very small pieces fell onto the seats and carpet, but I used more masking tape rolled backwards on my hand to clean it up ( kind of like getting lint off of your black pants.) Took me a total of 30min to do both visors.
pink wheels are cool
i'll have to try this out
UPDATE:
After a few days now -- Looks even better! I hate those ugly yellow stickers! |
After a few days this is what it looks like.
ellenbetty
Drives: 2 2007 Yaris 3 door liftback Join Date: Nov 2008
I would rather save my lungs and try something less toxic, like 440 sand paper.
![]() Drives: "09" yaris Join Date: May 2009
Sand paper is a bad idea. I was thinking about trying a heat gun
Looks like I found my next mod. Im sick of those things and i have tried to peel them off several times before.
"Chrome wont get you home" |
#11 | |
how bout something less hot, like a hairdryer.
| Paintless Dent Removal - Dent Magician | Chupacabra | General Yaris / Vitz Discussion | 3 | 01-27-2009 10:07 PM |
| Sedan Headlight removal | Go4th | DIY / Maintenance / Service | 1 | 02-04-2007 05:46 PM |
| Weight Savings - Removal, Reduction, Reminder.... | TRD_Yaris | Performance Modifications | 17 | 08-12-2006 02:07 PM |
