Old 11-06-2006, 12:28 PM   #19
control module and servos came up to about $350
Old 11-06-2006, 02:12 PM   #20
JeffForSale
buy me!
JeffForSale's Avatar
Drives: RX-7
Originally Posted by Galavoxx
$1k just for the absorbers seems a little high...
they're coilovers, its the spring and shock assembly
its dampening and and ride height adjustable
it'll allow you to run higher offset (read:wider) wheels and corner weight the car, etc
JeffForSale is offline   Reply With Quote
Old 11-06-2006, 04:28 PM   #21
SmellyTofu
好多人&
Drives: .
Originally Posted by boris13
"Nimble" sounds good to me too. I think I'm going to get the TRD sport shocks only (without the lowering spring kit), to firm up the liftback's cornering and overall handling. I want to maintain at least close to stock ground clearance (actually, I'd like MORE ground clearance, on the order of a Subaru Outback, but you can't always have everything!); I drive on a lot of bumpy dirt roads.
If you are going on bumpy roads, just check the design of the shocks before purchasing. monotube shocks like Koni don't have a good reputation for high stroke application (less room for cooling, oil bubbles up etc). I've had a set of Koni fail and start to leak oil. Bilsteins so I've been told quite good in offroad applications so you may want to also investigate that path if you are only doing shocks.
I don't know where the TRD USA are made, but the TRD Sportivo (Japan) are made by KYB but to TRD spec.
SmellyTofu is offline   Reply With Quote
Old 11-07-2006, 09:10 PM   #22
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Just found these on eBay. They look the business.
http://cgi.ebay.com/ebaymotors/ws/eB...6407646&rd=1,1
Galavoxx is offline   Reply With Quote
LB M/T options Howard2621 New YARIS Purchase Forum 1 09-22-2006 11:37 PM
Texas gal needs ur help please! fantabulousbaby New YARIS Purchase Forum 35 08-06-2006 11:09 PM
Factory Lowering Springs + MAX Wheels? What are the options? bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-24-2006 09:10 PM
Unable to order options? Epyn New YARIS Purchase Forum 7 05-03-2006 01:20 PM
Should I add remote key less entry? Options YotaYarisUSA General Yaris / Vitz Discussion 13 05-02-2006 06:06 PM
