![]() ![]() Drives: Red Yaris Join Date: May 2009
2007 Toyota Yaris HB Handbrake
The handbrake on these cars are self adjusting aren't they? We shouldn't have to ever adjust them correct?
-Phil |
#2 | |
My dealer adjusts it every service. I can tell when it needs an adjustment and just after one has been done. Just so you know the tires are not self inflating and the wiper fluid won't replace itself either.
![]() "Manual labour is not for me. In fact i'm not even sure non manual work is either." -Anthony Linton Check out ▬▬► I like I like ◄▬▬ for more fun on Facebook |
#3 | |
mine does , or so the wife thinks
#4 | |
-Phil |
Yes i'm sure. When I take it in for a service I need to lift the hand brake quite high. After they adjust the hand brake I don't need to lift it as high to get the same pressure.
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
Phil,
You are correct many are designed this way but in "real world" use seldem work effectively. Better to check them and adjust manually if necessary. R2 |
The rear drum brake will self adjust as stated.
However ocassionally the hand brake may (or may not) need adjustment to compensate for cable stretch etc. |
2 10mm open wrenches does the trick. just lift the center console up in the back. i always tighten mine up some so i dont have to pull 3 miles to get the brake to engage. not to mention it makes the random sliding a easier. :)
![]() ![]() Drives: 2007 LB Join Date: Jan 2009
The "problem" with the self adjusting rear drum brake is they only work when you back up and it takes some force to make the adjusters work. If you really think about it, how much do you back up? If you just back up 3 feet and gently touch the brakes it's just not going to work. When my rear drums start making a little squeaking I just make sure that I roll back a little further out of my parking spot and hit the brake sharply a couple of days and it goes away for a while. If that doesn't do it, then I start taking things apart.
#10 | |
I also develped the same habit years ago (with the cars that had rear drums) to ocasionally hit the brake a bit harder when backing up. |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Response from Toyota on my special order | drdavidr4u | New YARIS Purchase Forum | 14 | 04-27-2010 08:59 PM |
