Old 07-22-2007, 11:44 PM   #1
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
New Hitch Installed
Hi everyone,
After a previously failed installation (tried to install one for the Sedan on my Liftback), I managed to install a hitch this time! I ordered it online from reese-hitches.com, it's a Draw-Tite hitch (part number 24786), for $71.75 + $18.02 shipping. It took them a few weeks to ship, but eventually the hitch came and I started working on it. It was a little more complicated than I thought, didn't manage to get it done in one evening, before dark, I'd say it took me about 3-4 hours in total, because I ended up removing the rear bumper, so I can get to the upper screws. Reaching from underneath is almost impossible IMO. Let me know if you have any questions and I'll be more than happy to answer them.
Here are some pictures of it.
fmicle is offline   Reply With Quote
Old 07-23-2007, 09:45 AM   #2
ism3t
YarVitz
ism3t's Avatar
Drives: 07' Yaris Liftback
bikes are bigger than the car! i love it
ism3t is offline   Reply With Quote
Old 07-23-2007, 08:56 PM   #3
fmicle
fmicle's Avatar
Originally Posted by vasilios View Post
how much weight can you put on that before the front wheels come off the pavement? :) Looks good tho.
The hitch is rated for 200 lbs tongue weight, so no worries about losing the grip on the front wheels
Old 07-23-2007, 09:10 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
The hitch looks good. Nice installation. Too bad you had to remove the rear bumper. Was that difficult? Nice bikes!
Old 07-17-2009, 01:37 PM   #5
fmicle
fmicle's Avatar
It was kind of difficult, because there is little room for a wrench where the screws need to be tightened. I only had an angle of about 30 degrees, so it took me a while to turn the screws all the way. But it seems to be alright, 2 years later nothing is loose and I am getting ready to pull a sport trailer next weekend, for a camping trip. Will post pictures...
Old 07-17-2009, 03:08 PM   #6
POORSHA
POORSHA's Avatar
Drives: 2008 LB
Welcome to the " you cant do that " club.. Enjoy the hitch.
POORSHA is offline   Reply With Quote
Old 07-17-2009, 03:26 PM   #7
Can you worm your way in under there and take pics of the attachment points. I want to see how it differs from my Curt hitch.
Thanks
Old 07-17-2009, 03:52 PM   #8
fmicle
fmicle's Avatar
Yes, I'll try to get some pictures of the attachment points. I go under and do visual checks from time to time, just to make sure everything is still alright and pull hard on the hitch to check for any looseness.
I installed the wiring harness a couple of weeks ago and I'm quite proud of it, since I got everything under the plastic interior covers, so you can't see anything; the loose end rest inside the spare wheel when it's not being used. And U-Haul let me do a connection check last Sunday, all the lights seem to be working fine, whoo-hoo :-)
Pictures later after I get home from work... almost there ;-)
Old 07-17-2009, 03:59 PM   #9
Is there finally a plug-and-play wiring harness available, or did you have to splice?
Old 07-17-2009, 04:18 PM   #10
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
thats awesome. ive been looking at getting the hidden hitch so i can carry my track wheels and tires on it and not have to throw them in the car.
Old 07-17-2009, 09:22 PM   #11
fmicle
fmicle's Avatar
I had to splice, but that was easy, the kit had everything I needed, unlike the radio/cd/mp3 player installation, no soldering needed this time :-)
Old 07-17-2009, 09:47 PM   #12
fmicle
fmicle's Avatar
Okay, here we go, I took some pictures of the attachment points on the left side. I'm lying on my back under the car, right shoulder almost touching the left rear tire. I stuck my hand in one picture, to give you an idea about the available space. The lower bolt is easy, the higher one is a bitch, like I said I had to detach the bumper so I can get access from above. By the way, I had to remove 4 factory screws that were there and use those provided with the hitch.
Gotta go install the new cold air intake, before it gets dark ;-)
Old 07-17-2009, 10:50 PM   #13
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Very nice!
Old 07-18-2009, 12:49 PM   #14
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Thanks
I've been looking at the Curt and it looked fairly easy to install-how was it?
I bought a Curt for the wife's Rogue and it was very well designed and easy to install. I am very pleased with it so I was considering one for the Yaris.
TIA
R2
-The Fitful One
Old 07-18-2009, 02:29 PM   #15
saplaymate
saplaymate's Avatar
Drives: 08' HB
I have a curt, very simple and strong mount design.
0 - 60 in 3 shifts
saplaymate is offline   Reply With Quote
Old 07-18-2009, 03:05 PM   #16
yaris prime
Yes- I fit in it.
yaris prime's Avatar
Drives: 2007 Yaris liftback, MT
+1 for the Curt. Uses different attachment points than some of the others- very easy to install- did not need to remove bumper.
I'm surprised it doesn't have a pull-start !
yaris prime is offline   Reply With Quote
Old 07-18-2009, 03:30 PM   #17
Mead
Drives: BSP Yaris LB 2007
I gotta question... (obviously you dont have an exhaust) but do you think an after market exhaust will block the hitch? I have the medallion touring like this:
Mead is offline   Reply With Quote
Old 07-18-2009, 03:46 PM   #18
saplaymate
saplaymate's Avatar
Drives: 08' HB
It fits with my obvious Concept G. and will fit with any other exhaust!
0 - 60 in 3 shifts
Genuine Toyota Hitch for Yaris now available in Canada voodoo22 DIY / Maintenance / Service 8 04-22-2014 08:50 AM
Failed Hitch Installation fmicle DIY / Maintenance / Service 7 08-11-2010 04:15 AM
Towing Hitch for a Yaris fmicle General Yaris / Vitz Discussion 1 05-16-2007 08:07 PM
System is installed! Venom In Car Entertainment + Electronics (audio / video / alarm) 14 01-28-2007 07:06 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 08:45 AM
