#37 |
#38 |
#39 |
after reading that PDF again, they are shimless buckets, i.e. to adjust valve lift, you swap for thicker buckets from Toyota...
#40 |
![]() ![]() Drives: 05 Echo Join Date: Jul 2009
Well that pretty much makes it difficult, and unaffordable.
If I had to weld the cores, then grind them to maintain your stock lifter setup, that would make it too expensive. Sorry guys. |
#41 |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Oct 2008
Thanks for trying mike!
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress |
#42 |
let's keep the discussion open, this is super informative for me, and probably for others.
If Mike is willing? So when someone like GUDE sells cams for our cars, what exactly did they make then?
#43 |
Apexing Egg!!
i would love a set of NA cam regrinds
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#44 |
Doesn't post #41 indicate that you can't do a simple regrind? .. I'm a bit over my head on the technical part of this.
#45 | |
Wouldn't it be possible to offset grind the cams on their base circles and then use thicker buckets to take up the slack, thereby giving you more lift without running into coil bind? |
#46 | |
Learn to Relax
You have four valves already. Wouldn't better intake and exhaust manifolds with porting give more reliable results?
#47 |
It could, though higher lift/more duration would also make for better results with an intake and exhaust. Somone will have to measure the "worst case" valve clearance of this motor to be able to tell how crazy you can get on the 1NZ without the valves beating all of the pretty off the pistons, though with lower compression (hint Garm), there'd be even more room for lift, as the piston is either going to be flycut or dished to drop the compression, which would yield more lift potential.
#48 |
![]() ![]() Drives: 1990 Supra Turbo Join Date: May 2009
I believe that the 1NZ-FE motor is a non-interference design. So, hitting the pistons should not be an issue.
It might be possible to ditch vvti to help with tuning, however, that is a whole other issue. And having an exhaust cam alone might not be worth the hassle. |
#49 | |
ditching the VVTI is by far the worst thing you could do to the 1nz
#50 |
#51 | |
I'll keep an eye on the thread. Like I said, if I think we can do something, I'm game. Not sure what you mean by offset grinding the cores. |
#52 |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
this is an exciting thread! ;d hope to see more dev in this area
| Performance Camshafts | acer1958 | Performance Modifications | 2 | 11-09-2012 06:09 AM |
