Old 07-20-2009, 02:45 AM   #1
bibi-
Drives: yaris
17's and 205/45's. Is it Possible?
is it possilble to put on 17" wheels with 205/45 with OEM springs?
is it going to rubbing?
bibi- is offline   Reply With Quote
Old 07-21-2009, 02:23 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
205/45/17 is the Toyota OEM tyre size and recommended for 17" application with stock suspension.
Old 07-21-2009, 02:57 PM   #3
Penguin Garage
Penguin Garage's Avatar
Drives: Yaris
On stock suspension with 7" wheels as long as your offset is higher than +25 you shouldn't have any rubbing issues up front.
without more wheel info we can't really give you a certain answer on fitment, which wheels (size/offset) you looking to run?
Penguin Garage is offline   Reply With Quote
Old 07-21-2009, 02:57 PM   #4
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
OP, you need to make sure your wheel offset is +40MM to +43MM. width alone doesn't tell us whether or not it will rub.
Originally Posted by xnamerxx
you nailed it sir.
Old 07-21-2009, 02:57 PM   #5
Tamago
Tamago's Avatar
Drives: ZZW30
lol you beat me to it..
you nailed it sir.
Old 07-21-2009, 03:17 PM   #6
ChinoCharles
Drives: LB
Should the offset be above +25 or between +40 and +43? Information kind of conflicts there.
Old 07-21-2009, 03:27 PM   #7
Penguin Garage
Drives: Yaris
well the +40 to +43mm applies to the above +25mm.
the +25mm wont rub, although it may not be the look that everyone wants as it's rather aggressive.
Tamago's offset recommendations are true for a no hassle bolt on fitment (for stock or future suspensions), although the rear wheels will be sunken in due to the track difference.
we really need more info on the OP's goals to figure out what the best course of action would be. We'd at least be able to show him a few options.
we've ran as low as a +23mm with a 205 on a stock suspension yaris without rubbing.
Old 07-21-2009, 03:31 PM   #8
ChinoCharles
Drives: LB
I must say, too, that I installed your hub spacers last weekend and they're f'n fantastic. Thanks for making those.
Old 07-21-2009, 03:39 PM   #9
andries
aka Jack Wolfskin
Drives: Yaris
Send a message via MSN to andries
I have stock rims on my 1.8 TS. They are 17" x 6.5J and the offset is 52 mm with tyres 205/45/17.
My TS have a stock lowering of 0.5 inch and it gives no problems and no rubbing.
andries is offline   Reply With Quote
Old 07-21-2009, 03:41 PM   #10
kimona
kimona's Avatar
One thing to mention here with any wheel/tyre application on stock suspension: The lower the offset, the more you bring the wheels out, the more you visually accentuate the already monstrous Yaris wheel gap, and the more the car looks like a puddle jumper.
Old 07-21-2009, 03:57 PM   #11
Tamago
Tamago's Avatar
Drives: ZZW30
bringing the wheels out makes wheelgap more apparent? what about undersizing of tires.?
you nailed it sir.
Old 07-21-2009, 03:59 PM   #12
kimona
kimona's Avatar
bringing the wheels out makes wheel gap more apparent? what about undersizing of tires.?
Same goes for "undersizing of tires."
Old 07-21-2009, 04:02 PM   #13
Penguin Garage
Drives: Yaris
No problem here to help, glad you're happy with them
Shoot me a PM I has a question for you.
that's good to hear actually, more room inboard than previously thought.
Old 07-21-2009, 04:05 PM   #14
Penguin Garage
Drives: Yaris
same also goes for "up" sizing the wheels.
a 17" wheel with the same overall diameter tire will "appear" to have more wheel gap then the stock wheels.
I've actually found a proper low(er) offset actually makes the high ride height look better, although that could be a personal preference.
Old 07-21-2009, 04:12 PM   #15
ChinoCharles
Drives: LB
Puddle jumper... LOL I love it.
Old 07-21-2009, 04:13 PM   #16
kimona
kimona's Avatar
Yeah. That's my experience as well with +1/+2 applications.
