#55 |
oh yes winters are very cold here under the tropics
![]() thanks for the heads up though, I'll probably go for mobil 1 first then see about finding better brands, might need a lot of digging around.
#56 |
![]() ![]() Drives: 2007 Yaris Liftback Join Date: Sep 2006
What defines what a "cold" climate is? I can understand that people in the northern US/Canada would be considered cold, but I live in Texas. While we have cold (by our standards) winters, is it enough to justify going to a 0W-30, or should I just stick with a 5W-30. We might have a handful of days a winter that fall below freezing.
#57 |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
Opinons will differ BUT IMO a cold climate is any place that will see cold morning starts where air temps are below 10 oC.
But A cold engine and cold climate are two completely different things. Even in a moderate to warm climate a cold engine is a dry engine and the first minute of running will cause the most damage. A 0w-30 won't hurt anything run in any cliamte including a tropical cliamte. the 0W just provides easier starting and less engine damage when the engine is cold and even more protection when air temps are a bit colder. The 0W will allow the engine to run easier when cold, and provide instant and higher oil flow to an engine that's warming up or driven cold, and helps reduce start up engine wear better then 5w or 10w-30 oil. In texas you are likely perfectly fine with a 5W-30 but the 0W-30 wont hurt, If you are talking about Amsoil the 2000series 0W-30 is a better oil then the 5w-30 which contain less Esters base stocks. Amsoil 2000 is a group IV-V blend Most of the others he others are group IV XL is group III-IV blend
The early bird gets the worm, but the second mouse gets the cheese. |
#58 |
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3 Join Date: Oct 2006
dam man, you really know your shit when it comes to oil. i admire your knowledge and thank you for sharing such great information!
planning on running amsoil in my yaris. should i go ahead and just run the engine to 1000 before switching over? i'm sure i could probably change the oil right now but i am kind of broke so waiting until 1000 would be better on the wallet. plus i am sure it won't hurt the engine much more anyways, right? |
#59 | |
HardlyDangerous
You can wait until your first scheduled oil change to switch to what ever oil you decide to run. Usually 3000-5000miles You can switch before if you want but there is no need to waste $$$ I would recommend start driving the car as you normally would (if you have not been already) and then change it anytime. I changed mine at 5000km (3000 miles)
#60 |
![]() Drives: yaris sedan 07 BLACK Join Date: Aug 2006
OMG, just had oil changed to synthetic this Saturday on my older Toyota 4runner (1994, 171000 miles). I went to the Oil Change station that I regularly visit to do oil change, asked for a engine flush and then they changed oil to Amsoil that I purchased separately. What can I say? Thank you for a wonderful input and explanations here. What a difference in driving performance. You just feel it right away, how smoothly my car run, how differently more silently the engine works, how much better the accelaration works. You just feel it
#61 |
Oh, our Yaris is so getting synthetic too after first 5000 miles.
#62 |
HardlyDangerous
Thanks
Sounds like it put a smile on your face... An entire engine, tranmission and differential fluid change using group IV-V lubricants can give you up to 10 free HP. That's a very noticable seat of the pants difference that can be seen and felt. I think the royal purple website vids show gains up 8hp just by switching over
#63 |
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
It's official people. The best oil to use is right here in this technical service bulletin. 5W-20 or 0W-20 straight from Toyota. Since 5W-20 and 0W-20 can't be made with straight dino, Toyota is telling you indirectly to use Synthetic, or a Synthetic blend. WOW! Finally and end of discussion about dino or synthetic. Kinda like ID and Evolution discussion. hehe
TSB EG018-06
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum Last edited by nsmitchell; 11-09-2006 at 08:54 AM. |
#64 |
HardlyDangerous
Be careful using 20 weight oil
Read the NOTES It says to use the oil recommend on the oil cap or in the manual as each engine/car may require different viscosity grades. Keep in mind a 20W oil is for normal driving conditions only. Do not use them in a high mileage car or engine older then 2006 Do not use them if you run you car under hard conditions, heavy loads or race. I personally would not run any 20W oil in my car, I'm not that desperate for a mile or two more per tank or cold engine performance. IMO a 0W-30 is still the better overall protection. Same great cold performance as a 0w-20 but better Hot protection then a 20 weight oil.
#65 |
![]() ![]() ![]() Drives: 2007 Yaris Liftback, 5-speed Join Date: Oct 2006
I'm planning on switching to Red Line 5W30 after about 7,000-8,000 miles. Does that sound OK for an upper Midwest USA climate? (Red Line doesn't make a 0W30.)
#66 |
![]() Drives: 07' Liftback, man., Bayou Blue Join Date: Sep 2006
The manual and oil fill cap for my 07' liftback say to use 5 W 30 so that is the viscosity I will use. Toyota takes no position on synthetics or synthetic blends. The ILSAC GF-4 specification is the API SM designation (SL is GF-3; SJ is GF-2).
#67 |
The TSB, which is an update, applies to the Yaris. I'm sure the oil filler caps were created on the original specifications, now those have CHANGED for NZ series motors, like our 1NZ-FE. If you simply went by the oil filler cap, no TSB would have been needed. The reason Toyota is doing this is to improve their MPG average anyway, but what I find interesting is that these 5W-20 and especially 0W-20 oils only come in synthetics! So Toyota stock brand for these engines will be synthetic or at least a blend. This puts to bed the argument FOR DINO ONLY debates. 0W-30 is still an excellent oil and provides better protection. I believe that a synthetic 0W-20 or 5W-20 will still provide excellent anti-wear benefits though.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
#68 | |
HardlyDangerous
#69 |
NCP91
Drives: 06 Vitz RS Join Date: Apr 2006
Motul 8100 0w30 all the way!!!!
#70 | |
![]() Drives: 07 Yaris S Join Date: May 2006
Mike
Experience is the best teacher...IF you can afford the tuition! |
#71 | |
![]() Drives: yaris sedan Join Date: Oct 2006
And please dont act like you know it all, allow other people to have different opinions |
#72 |
Well, I have changed the oil to synthetic 2 weeks ago, as it was noticed, already, the car performance is outstanding, but today I noticed, that the arrow on the oil pressure indicator kept standing right on the border between Low and Normal
I clearly know, that right after the oil has been changed it was in the middle position of Normal. I also know that after the engine flush technician put only 1.25 gallons of oil in the engine, but not 1.5 gallons, as my 3.0 engine requeres (may be not? forgive me my arrogance).... So, I am thinking, why the oil pressure reduced after 2 weeks of driving.... I read somewhere here, that engine flush with concequent change to synthetic oil cleans up all the system from clogs and debris.... may be after this procedure it cleaned it so intensely that now I can have a leak somewhere ( the car is older one, 1994) or it might happen because the technician didn't put enough oil in the system.... Any advice is very appreciated....
| LB M/T options | Howard2621 | New YARIS Purchase Forum | 1 | 09-22-2006 11:37 PM |
