Old 07-29-2009, 03:44 PM   #1
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
GT Spec or Ultra Racing?
What "mid-car" under bracing is better? (UR is the white one GT is the blue one)
Old 07-29-2009, 03:53 PM   #2
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
NEITHER save your money.....
Old 07-29-2009, 03:56 PM   #3
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
If your mind is set to buy these frames... then the cheaper is the better..
Old 07-29-2009, 03:58 PM   #4
ROCKLAND TOYOTA
TRIM HUNTER
FYI: those bars will work together if you so choose....
Old 07-29-2009, 04:00 PM   #5
kngrsll
Apexing Egg!!
kngrsll's Avatar
i wish i had pics of where some of the bars go. Some of the Ultra racing bars are kinda hard to figure out where they are going exactly.
i have heard fender braces should be a good mod for our car, i think Tamago suggested that as well.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 07-29-2009, 04:29 PM   #6
Those aren't the same thing.
The UR braces are side underbraces, the GT Spec is a centered underbrace. A more fair comparison is underbracing from both companies that goes in the same location.
Old 07-29-2009, 04:53 PM   #7
lilredrocket
Slowy getting there
Drives: 08 Liftback
Are you sure these will work together? I didn't think there was that much room under there. The reason I asked is I thiught they went in the same spot or used the same mounting locations. Also I'm auto-xing my car and have read around here that under bracing really stiffens up a car. So I guess I really want to find out what type of under bracing will help me out. (i'm not buying it now it's for future reference) I sould be getting new tires really soon. That's first then different springs and shocks/struts or coilovers.
Old 07-30-2009, 10:24 PM   #8
botchilah
Drives: white and red shiny things
Worked on mine, had a tremendous improvement in chassis rigidity. I put on ALL the braces of UR though. Worth the money. And it's actually quite cheap compared to braces from CUSCO, Carbing, NAMS etc. My Yaris used to flex like a noodle with only me on board on completely stock suspension.
Although they aren't the exact same braces, I think those two types braces use two or more similar mounting points into the chassis so they might not work together or at least you won't be able to mount them together.
IMHO go UR all the way. So you can get all their braces to work together mounted on your Yaris. You might also want to take a look at UR's room bar. Mounts between the b-pillars.
08' Yaris HB 5dr: RAYS 57 Motorsports 17X7 / K&N SRI / TANABE axleback exhaust / ULTRA RACING complete braces / MEGAN RACING complete braces / NEX coilovers / NEX 330mm 4-pot front BBK / PENGUIN GARAGE hub spacers / HOTBITS headers / BUDDY CLUB oil cap and rad cap / APP SS brake lines / HKS synthetic lubes / RECARO SR5 seats / TRD shiftknob / cheap FEDERAL (free) tires lol. NEXT: HKS F-CON iS
botchilah is offline   Reply With Quote
Old 07-31-2009, 02:48 AM   #9
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
Well it made a hell lot of difference in my car.
I have the complete set of bars from Ultra Racing besides the middle lower member brace and room bar.
You might want to check out the following link if you have any doubts about the rigidity of their bars.
http://www.ultraracing.com.my/template.asp?menuid=28
Cheers! :)
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 07-31-2009, 06:11 PM   #10
jt258
jt258's Avatar
Drives: 10' corolla ce
I HAVE JUST HAVE THE FRONT AND REAR BRACES ALONG WITH REAR UPPER &LOWER STRUT BRACES ON MY CAR AND THEY MAKE A BIG DIFFERENCE PERIOD.
jt258 is offline   Reply With Quote
Old 08-01-2009, 01:23 AM   #11
lilredrocket
Slowy getting there
Drives: 08 Liftback
What brand are your braces?
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
ULTRA RACING braces botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 25 06-05-2009 03:20 AM
