![]() Drives: 3dr hatchback Join Date: Jul 2009
Cruise light missing?
Hi everyone! I just purchased and picked up my (
). It wouldn't be such a huge deal if i could see the little green light on the cruise wand light up, but alas, the positioning of the light and wheel and myself don't alight (go figure!). Since I had the cruise installed before I picked it up form the dealer I am wondering if maybe the dash display just doesn't have the light build in? Should I take it in and have then fix it? other than that the car is amazing, SO glad I bought one!
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
if your cruise stalk is on the left hand side of your steering wheel, then it is after market and does not have a light on the dash, or any other indicator aside from the cruise switch being "on" (green).
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
You have the Rostra Cruise Control which is what Toyota uses as it's after market kit or for vehicles that do not have the power package. This means you will not have a light on your gauge panel. You will only have the green light on the stalk itself.
Knowing is half the battle!
Darn, oh well! Thanks for the reply guys! The dealership gave me the option of paying $400 to have one with cruise shipped in, or paying slightly less and having then install one so I could get the car quicker. I didn't know there was a difference really.
If your car has manual windows and locks then you would have had the same cruise installed wether or not you had it done by the dealer or before the dealer.
SRacer
check your manual for reassurance...
"If I go down, I do time. I do real time. I don't know about your other drivers but when I see flashing lights in the mirror I don't stop." - Dominic, Fast & Furious ![]() Learn The Truth about Six Pack Fast! |
#7 | |
Here's where the indicators are located on my 09:
Thanks I DO have the light there, I will have to check out about getting and OEM stalk, thanks!
#9 | |
http://www.yarisworld.com/forums/showthread.php?t=16188 http://www.yarisworld.com/forums/showthread.php?t=17158 |
Lots to read
Wow, there is a lot to read on those posts. I am going to read it over, perhaps there is a way to modify my after market Rostra stalk to trigger the cruise lights as was done in the second link you so generously gave. I did look over that thread before but it didn't click first time 'round.
![]() Drives: Yaris 5 Door Liftback White Join Date: Aug 2009
I have the same problem - the dealer had the cruise control installed for $250 (I know, it's MSRP, but they just wouldn't buldge). I have it now, but the light is NOT lit :(
I left them a message, let's see what they have to say about this... |
If the stalk is on the left side of the steering wheel it is not suppose to have a light on the dash.
There are two kinds of CC on the Yaris - Factory and Dealer/Port Installed (=aftermarket). Factory lights the combo meter lights and Dealer Installed has a tiny little LED on its own stalk. The two are two completely different ways of accomplishing the same thing.
#14 |
Yes, the dealer just gave me a call back, and they said the same thing. I still wonder if there is a way to activate the light by doing some creative wiring
![]() I've sifted through DIY links above but found nothing so far that would specifically discuss how to activate the light with the dealer-installed after-market cruise-control. Any help will be appreciated. Thanks guys!
#15 | |
The more complicated answer is yes. To have the Rostra unit drive the cluster light, you would have to get a two conductor wire from the guts of the Rostra stalk to the guts of the cluster. You would then need to cut the traces on the cluster PCB to isolate the cruise LED from the cluster's microcontroller. Finally, you would connect the LED output of the Rostra to the now isolated cluster LED. |
#16 |
i wonder why dealers do not install the OEM stalk on 09's ??!
#17 |
Probably because they have no idea that it will work. The only officially documented upgrade to cruise is with the kit.
#18 |
| Tags |
| cruise, dashboard, light |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 04:43 AM |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 02:50 AM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 04:55 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 11:42 AM |
