Old 07-29-2009, 11:37 PM   #1
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
NEED HELP
I tried to change the turning signal lights puting 2057LED insted of 992(7440A) wich are the one for it Well now my turning signals are not working at all or the hazard ones ANYONE KNOWS WHY?Could it be a Fuse? But where is the Fuse box and what fuse is it?
Originally Posted by sw07gt
Old 07-29-2009, 11:41 PM   #2
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
when you say you tried to replace it, do you mean you put the old ones back in after the new ones didn't work?
Old 07-29-2009, 11:46 PM   #3
LEGATO``
LEGATO``'s Avatar
try what he said
put the old ones back, and if that doesnt work, then it might be the fuse
Project LEGATO
Old 07-29-2009, 11:54 PM   #4
JumpmanYaris
USAF_SrA_E-4
I did try that to but i was replacing the left side and the right side isnt working
Old 07-30-2009, 12:28 AM   #5
Shroomster
Shroomster's Avatar
there is no light from any corner of the car when you flip the hazards?
highly unlikely that you popped a fuse as the bulb itself acts like a fuse to begin with, but if you reinstalled the original bulbs then yeah check the fuses.
Old 07-30-2009, 11:07 AM   #6
JumpmanYaris
USAF_SrA_E-4
Yup I tried switching the bulb to the original and the led one as well and no results I need to find where is the fuse so I can check them if not... as much as I dont want to im gonna have to take it to Toyota
Old 07-30-2009, 12:36 PM   #7
It's the 10A one labeled "TAIL" in the fuse panel that is up under the dash (i.e. the one you put your head on the brake pedal to see).
Old 07-30-2009, 12:41 PM   #8
A 2057 is a bayonet mount and a 7440A is a wedge mount.
Out of curiosity, how did you install it?
Old 07-30-2009, 01:01 PM   #9
SaerinRhoe
'09 Yaris
Drives: '09 Yaris
With duct tape and bailing wire.
Just trying to add some humor.
S.R.
2009 Yaris 3-Door Liftback MT Black Sand Pearl
SaerinRhoe is offline   Reply With Quote
Old 07-30-2009, 05:10 PM   #10
JumpmanYaris
USAF_SrA_E-4
Well its the tail lights from Garm so the bulbchanges its not the same plug that the original taillights comes with
Old 07-30-2009, 05:35 PM   #11
OK. So you had the rewire to connect up the new lights, and at the same time you were changing the new ones to LEDs?
Did you find that the fuse was popped?
Old 07-30-2009, 10:35 PM   #12
JumpmanYaris
USAF_SrA_E-4
I havent checked to much work I will try and see wich one and where it is I will post some pictures of the plug for the bulb so you can see.
Yes its all rewired but they been working for almost a year and now that I wanted them LED amber lights this crap happens
I PRAY TO GOD IT'S JUST A MESSED UP FUSE!!
Old 07-30-2009, 10:37 PM   #13
The lighting circuits are well protected, so I would almost guarantee that it's the fuse.
Old 07-30-2009, 10:39 PM   #14
JumpmanYaris
USAF_SrA_E-4
hopefully...
Old 07-31-2009, 03:23 PM   #15
JumpmanYaris
USAF_SrA_E-4
Here are the picture i took some of them off and checked them the ones i did are good the thing is wich one is tha one for the signals?!?!
Old 07-31-2009, 03:32 PM   #16
The 10A one at the bottom left of your picture is the tail light fuse if you are working on a liftback.
By the way, I'm not digging that white wire stuffed in the meter fuse. I don't think it's part of your current problem, but it's not a good way of doing things...
Old 07-31-2009, 03:39 PM   #17
JumpmanYaris
USAF_SrA_E-4
Its the sedan but ill go check reall fast as far as that wire i got jack clue what it is it could be from when they installed the Remote Control or the Sound system i could be wrong thats the only 2 things that i have in my car
Old 07-31-2009, 03:47 PM   #18
JumpmanYaris
USAF_SrA_E-4
If is that one its intact
