Old 08-10-2009, 04:05 PM   #1
jorizk
Drives: Yaris 2006 1.5 L Sedan
Question I think it's a battery problem.. don't you ?
Hello fellas :) How are you ?
Since a while a go I was cruisin in my 2006 yaris sedan, when I parked to get my friend. I left the radio and the lights on (low beams + fog lights) for like 7 or 8 minutes but the engine was turned off. Now when I pushed the ignition switch the engine would not turn on. Same things after a couple of tries. Then I turned off the lights. I tried once more, the engine started, but the starting phase (the part when the electrical motor does the work) seemed slow and hard on the car.
The thing is that the battery is stock and of course it must last more than three years:S What should i do ? Should I replace it ?
I would appreciate your suggestions.
jorizk is offline   Reply With Quote
Old 08-10-2009, 04:15 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
don't leave lights or stereo or any electricals on when the car is off... that is why batteries die prematurely. 7-8 minutes may not seem like much, but take a look at the fuse rating for your lights & radio (plus amps if you have them)... and you'll start to realize that thats a big drain, for an extended period.
so suggestions.
1: don't leave stuff on when the car is off, it kills your bat
2: don't start your car when stuff is turned on... turn stuff off, then start the car (allows the battery to dump more current, quicker into the starter)
3: you are going to have to replace your battery... if you continue your current habbits it might be a matter of days or weeks.... if you change your habbits and are lucky you might get months or even a year or so more.
Old 08-10-2009, 05:04 PM   #3
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
yeah that happened to me... Now i dont listen to my radio while the car is off.. and i also start the car up with nothing on.. no ac no radio.. makes for a much quicker easier startup that you will notice
Its a Chao!!!
Old 08-10-2009, 05:50 PM   #4
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I replaced the stock battery a couple weeks after I bought the car for the very reason that it drains too quickly.
Old 08-10-2009, 05:56 PM   #5
supmet
Drives: 2007 4 Door Yaris
lol?
My almost 3 year old battery still fires every time first try. Never had to jump it, charge it, or anything.
Just leave your car on. It costs about 75 cents an hour. (and the hypermilers will love you)
Old 08-10-2009, 07:27 PM   #6
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
The dealer might replace your battery for free
Old 08-10-2009, 11:37 PM   #7
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
The reason, at least for me why the car started to start slow during ignition turning was.....corrosion on battery terminal. After the cleanup, it hasn't done it again.
Did you have corrosion on your terminals, that's a cause most of the time~
Old 08-11-2009, 12:42 AM   #8
Altitude
Altitude's Avatar
Originally Posted by supmet View Post
lol?
Yup. I've never had a battery as weak as the one they use in the Yaris. I'm sure it suits its purpose as long as that purpose never involves running electrics without the engine running.
Old 08-11-2009, 12:37 PM   #9
jorizk
mmmm Oh okay :)... Now There's a thing i used to see my father do to his old car's battery, he fills it every now and then with distilled water. I guess it makes the acid reacts with the whole metal plates. Do you think that I must do the same ?
Old 08-11-2009, 01:59 PM   #10
Altitude
Altitude's Avatar
Most modern batteries are "maintenance free" meaning you don't need to add water/electrolyte to them anymore. I haven't checked but I'm pretty sure this is the case with the stock battery.
Your best bet is to either not run the radio, lights etc. unless the engine is running or just buy a better battery.
If you do neither and this happens again, then you will have to turn everything off and wait some time (10 mins or so) before the battery recovers enough to be able to crank it. If this happens a lot you're just shortening the life of the battery.
Old 08-11-2009, 03:27 PM   #11
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Mine says maint free too...
I have no corrosion to speak of on my bat after 1.5 years... but I do have blue foam around the negative terminal... Guessing its from the battery bubling out the top... bats bubble internally when gasses are released during the chemical reaction... maybe happened one of the many times I jump started the GF's truck. Takes a lot to charge a 1000ca battery
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 03:40 PM
electrical problem with car need help badly!! Adriaan DIY / Maintenance / Service 20 05-07-2010 01:40 AM
Yaris 06 H/B Engine Cutting out problem.. Farenheit General Yaris / Vitz Discussion 3 09-14-2007 02:21 PM
Urgent:Stupid problem with battery Katana DIY / Maintenance / Service 8 09-02-2007 11:36 AM
