![]() Drives: yaris Join Date: Aug 2009
throttle body change ?
My Yaris 3dr is up for 30 K service .The service guy at Toyota told me that the throttle body needs to be changed.It costs about 150$..What is this exactly ?let me know .
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
Welcome to Yarisworld! The throttle body is the butterfly valve that allows air from the air filter to flow into the intake manifold, which goes into the engine. Think of it as a direct extension of the gas pedal. For $150, it's not too bad, but I'd still try to find a lower price. And having this replaced at only 30K, I'd be suspicious of the dealership. But good luck to you anyway!
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
![]() ![]() ![]() Drives: Loaded 2007 mica silver sedan Join Date: Sep 2007
Should be covered un warranty, 3 yrs or 36000 miles for the basic warranty and up to 60,000 on the drive train.
Heart Up! Vitz
Drives: トヨタ Vitz Join Date: Jun 2007
swap for a Corolla or Celica throttle body :) Find one at junk yard.....
Thats my 2 cents if i had to change mine out that early? |
shouldnt need replacing at 30k....and if it does it should be covered under warranty
have you noticed anything awry w/ your car?
something dosnt sound right here
Ask why it needs to be changed... it SHOULD be good for like, forever. I will ask at work in the morning and let you know if it is normal, but it sounds to me like a problem occured and they don't want to pay for it themselves.
#9 | |
$150 wouldnt even be enough to cover the cost of the throttle body
#10 | |
Okay..... I JUST talked to my service guys, and they want to make sure you doidn't change anything on it. Cold air intake or anything? The ONLY reason they would charge you is if there was an outside influence that caused it to malfunction. Your car is not 3 years old or over 36K miles, right? You should still have FULL warranty on it then. Tell them to explain in writing what is wrong, and exactly what they are charging you for. Then take it to another dealership and have it serviced there from now on. If they are going to charge you for this, who knows what else they might be charging you for that missed your eyes. I wished you lived near me, because I would LOVE to help you keep your car maintained so you can keep driving it for YEARS to come. I would rather have a customer happy that sees me once overy 5 years then one that isn't happy and sees me every two years.
even an intake shouldnt screw up your throttle body...UNLESS you ran w/o a filter and sucked up a bird or small rodent
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
| Throttle body gasket+ oil change gaskets PICS | auxmike | DIY / Maintenance / Service | 4 | 12-01-2008 09:43 PM |
| Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-01-2007 11:38 PM |
| toyotafest 2007 | esquiva | Photo-Video-Media Gallery | 36 | 05-15-2007 12:03 PM |
