Old 07-22-2009, 09:19 AM   #37
jadz
Drives: 08' Yaris, 03' Sequoia
HVAC ODOR: 2008 Models?
I have a 2008 Yaris Sedan and I'm experiencing the same HVAC odor. From looking at the TSB it does not appear that my 2008 Yaris is covered.
Has anyone had any experience with getting this issue fixed on a 2008/2009?
jadz is offline   Reply With Quote
Old 07-22-2009, 12:41 PM   #38
jadz
My wife brought it to Toyota today and they indicated they could not find any source of the smell (leaves mold etc) and they recommended that we turn the heat on occasionally to dry it out...?
Old 07-22-2009, 12:48 PM   #39
Lafiro
Drives: 06 Yaris Sedan
I really hate how toyota made a car that could do this to us.
I tried lysol and it worked for 1 day.
I poked the hell out of the pipe that allows the water to drip out, and nothing, it works like it should. So I wonder where the mold is exactly, and how in the world to get to it.
Something tells me the dash or the bottom half has to be taken apart and the system removed? This car is becoming very annoying to own because of this alone.
Old 07-25-2009, 11:50 PM   #40
jadz
What would be the process or approach to take to try and get this fixed under warranty even if it is not covered under the TSB?
-Jadz
Old 08-11-2009, 06:14 PM   #41
08YarisAZ
Drives: 08 Red Yaris LB
Here is an update on my car. I'm now in Huntsville, AL and my car started smelling like mold after a month or two of being here. It actually smelled kind of like wet dog. I got a hold of the TSB from CTScott (I appreciate it), and took into the local dealer. They are going to replace the evaporator and the amplifier (what the heck is an AC amplifier) under warranty since I only have 32,000 miles on it. But it's going to take two days. They have to remove the entire dash and the center console. They want the two days just to make sure they don't have to hurry the job. They also have to order the part in. They are providing me with a free rental car - Toyota is being billed for it as warranty work. I hope this gets rid of the odor, and I will tell you how it works out.
How come none of you that had the work done haven't told us how it went? All I read is that how much the dash will be damaged. And by the way, I did the lysol thing over and over. It would last about a day or two, and then the smell would come back. I also checked the drain, holes under the body/floor and so on. This is the last resort to getting the smell eliminated.
I work with a guy here that has a 2007 HB with 46,000 miles, and he has no odor. The car smells just like brand new (as mine used to). But his model wasn't affected by the TSB.
08YarisAZ is offline   Reply With Quote
Old 08-11-2009, 08:44 PM   #42
The "AC amplifier" is the ECU for the AC.
See if they will hang onto the air box until you pick up the car, so you can see it (and snap some pics).
Old 08-12-2009, 07:26 AM   #43
jorizk
Drives: Yaris 2006 1.5 L Sedan
Well I have an odor in particular situations. If I turn the ventilation without the A/C button pressed, the odor is terrible. If the A/C button is pressed, then the odor disappears completely.. Very weird.. (I'm talking cold air)
jorizk is offline   Reply With Quote
Old 08-12-2009, 12:38 PM   #44
flutie98
Drives: Toyota Yaris
Same situation here, and the smell in the morning when i hop in the car is just nasty, smells like feet cheese. AC blowing for a couple minutes usually kills it but its still disgusting. Im taking it in with the bulletin tomorrow.
flutie98 is offline   Reply With Quote
Old 08-12-2009, 01:54 PM   #45
elmo
WFO
elmo's Avatar
Drives: 2008 hb
my 08 hatch doesn't smell bad guess i'm just lucky :)
elmo is offline   Reply With Quote
Old 08-12-2009, 02:32 PM   #46
b_hickman11
Drives: 08 Sedan
The TSB is only for certain 07 models so you shouldn't have a problem.
Old 08-12-2009, 03:51 PM   #47
08YarisAZ
Actually, it is for 07 and 08 models. Mine is an 08.
Old 08-12-2009, 06:59 PM   #48
b_hickman11
Drives: 08 Sedan
So there is a newer TSB than this one posted on the TSB thread?
Old 08-12-2009, 07:25 PM   #49
Yarisight
Yarisight's Avatar
Drives: 2008 Yaris LB "S" Blazing Blue
+1 is there a TSB for 08's as well? Anyone know?
Blazing Blue...Through and True...
Yarisight is offline   Reply With Quote
Old 08-12-2009, 08:17 PM   #50
Yes. This one supersedes the one above:
T-SB-0103-09 07-08 HVAC Odor.pdf
Old 08-13-2009, 03:24 PM   #51
helphelp911
Drives: yaris
Hi, Does that TSB work in Canada?
my car smell stink and i want to fix it
Thanks
helphelp911 is offline   Reply With Quote
Old 08-13-2009, 03:40 PM   #52
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
my 08 hatch doesn't smell...tho I hardly use the AC.
Old 08-13-2009, 04:31 PM   #53
helphelp911
Drives: yaris
for me, the faint smell come when i turn on he air con (strongest). Sometime when i turn on the fan ( first time during the day), the smell will come out too
Old 08-13-2009, 05:15 PM   #54
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
i wonder if humid climates are primarily the only places that this problem seems to appear... the first 7-8 months of ownership my car was in a very dry place... the past year I've been in a climate that changes from misty/rainy to very dry depending on the season.
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 09:59 PM
service at toyota THEDON DIY / Maintenance / Service 4 04-24-2009 02:45 PM
Does Toyota have a website for recording vehicle service? YarisOwnersDad DIY / Maintenance / Service 4 04-05-2009 12:42 AM
Funny Business at the Toyota Service Centre *MAD DOG* DIY / Maintenance / Service 10 01-10-2009 01:47 AM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 04:16 AM
