Old 08-18-2009, 09:02 AM   #1
DorytheYaris
aka Eleni
DorytheYaris's Avatar
Drives: 10 Yaris LB Auto- Blazing Blue
HELP! My cat peed in my front seat :(
x
DorytheYaris is offline   Reply With Quote
Old 08-18-2009, 09:18 AM   #2
90tsi
90tsi's Avatar
Drives: 09 yaris
my moms cat pissed in my dads 03 tacoma a few weeks ago. he pulled all the interior out and scrubbed it all including the floor boards. if its just your seat you need to get it out asap so the smell doesnt absorb into the rest of the interior. steam your seat and leave it out of the car. my dad left his truck apart for about 4 days or so with a fan on it.
90tsi is offline   Reply With Quote
Old 08-18-2009, 11:09 AM   #3
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
There is a product that you can buy at pet stores that spray on a chemical that neutralizes the urine and gets rid of the smell.
Old 08-18-2009, 12:44 PM   #4
tomato
tomato's Avatar
Aww man, I feel bad for you. I would definitely get that seat out of there, and leave it out some place until the smell is all gone. I don't konw what products to use but I would try to get the seat out ASAP. Sorry.
The neighbor's cat peed in my car once when I forgot to close the windows overnight (it was summer). It took a long time to get rid of the smell, but eventually it went away. (believe me, I **** ALWAYS*** remember to close my windows now!! )
Old 08-18-2009, 12:58 PM   #5
Bob Dog
DARK PHASE OF THE MOON
Bob Dog's Avatar
Drives: 07 liftback
check the pet store
Bob Dog is offline   Reply With Quote
Old 08-18-2009, 12:59 PM   #6
tomato
tomato's Avatar
Yeah, I don't know about any of these solutions, sorry. I guess you already tried Febreez?
Urine is a tough one. YOu probably need some specifically designed product to get rid of that one. The honda lost the smell on her own eventually, after leaving the windows craked open for weeks (well after cleaning the inside, but I didn't buy anything special, just used regular, strong carpet cleaner stuff. The car was old, though so I didn't care, I used what I already had at home under the sink).
Good luck and let us know how you manage to get rid of the smell.
Yeah, the cat probably got scared in the car. If it makes you feel any better, my dog threw up in the car the first time we drove him home.
Old 08-18-2009, 01:05 PM   #7
tomato
tomato's Avatar
Yeah, it will but you have to help it a little bit! ;)
Sorry about your car, man that s*cks, a brand new car, too!
Old 08-18-2009, 01:08 PM   #8
Couple of home rem's for you would be to use mouthwash and water (2/1) mix or vinegar and water (same mix). Pour it on and let it stand for 15 minutes and dry as much as possible. The smell of the mixture will go away after a few days. Off the shelf products like Pet Out can work, but are expensive and don't usually get all the smell out.
Old 08-18-2009, 01:15 PM   #9
another more harsh way (aftersmell) would be amonia and peroxide and it won't harm the fabric I'm pretty sure (even mix again). works great on home carpets so you might test it first.
Old 08-18-2009, 01:55 PM   #10
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Originally Posted by DorytheYaris View Post
Read about Nature's Miracle. I heard it costs a lot and it doesn't do the trick.
We use it at our house for the carpet every now and then. It seems to work for us.
Old 08-18-2009, 02:12 PM   #11
Too bad the fabric is different on the 09s. The wrecked Yaris that I picked up has a good passenger seat, but the fabric is the 08 blue dot type (and it is a bit sun faded)
Old 08-18-2009, 02:19 PM   #12
^ The main problem with the OP's seat would ultimately be the seat foam retaining the moisture/smell/residue from the urine. The fabric would be easy to clean and be effective when clean. It is possible to seperate the foam from the fabric and send the foam to the OP to use. Using new adhesive to apply the skin/fabric from the 2009. It's an option and would solve the issue of having to deal with the smell and lingering effects of urine. maybe you guys can work that out
Old 08-18-2009, 02:23 PM   #13
Not a bad idea, especially considering that the 09 has the airbag in the upper portion. The fabric is glued to the foam, but that wouldn't be a big deal for a auto upholstery shop.
Old 08-18-2009, 02:26 PM   #14
yep, no problem at all really to get off. I've done it a hundred times on other cars to dye to the fabric. This would take time to do, but to me is the best option without dealing with the cleaning chemicals and will or will it not work. This is a sure thing.
Old 08-18-2009, 02:48 PM   #15
90tsi
90tsi's Avatar
Drives: 09 yaris
so a huge question... how long has this set in before you messed with it? or have u tried several different methods? my dad got lucky because as soon as he got home he pulled everything out and scrubbed and steamed it right away so thats what made a huge difference..
Old 08-18-2009, 03:51 PM   #16
Slitwrist Smile
Drives: 2008 yari sedan/2007 sc'd tC
screw all these "home remedies"
go to the grocery store and RENT a "rug doctor". Buy the "upholstry" cleaner (not carpet). The cleaner also has "resolve" in it, and will scotchguard your seat for further r-kelly escapades. The rug doctor, should have a "wand' hand attachment to use with the machine.
Yank that seat out IF YOU CAN. If not, just clean it while its in there.
DO THE WHOLE SEAT about 10 times. Then, after that.. do it 10 more times... this is PISS after all..
Afterwords, let the seat AIR OUTSIDE if you can, if the seat did not get taken out, MAKE SURE TO LEAVE YOUR WINDOWS CRACKED 1/2" so the water/chemicals can escape the car. PARK IN THE DIRECT SUN if you can.
Then, hit it with fabreeze for about 1 week while your driving. I would NOT run the a/c in the car at all.. if that smell soaks into your a/c unit youll never get the funk out.
AFTER ALL THAT - go buy a 3 pack of vanillaroma trees... open ONE and sit it under your seat. 1 week later, open another one, then ONE MONTH later, open the last.
Guarantee that piss smell will be gone. Also post pictures of your kittah!
I had a ragdoll cat (best breed ever) in all white.. i loved her so much!
Slitwrist Smile is offline   Reply With Quote
Old 08-18-2009, 03:52 PM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
least helpful suggestion of the day
next time use a cat carrier
Old 08-18-2009, 03:53 PM   #18
tomato
tomato's Avatar
To the OP: One more idea, maybe stupid but here goes. Any chance you could just take the car out to a professional detail place and have them deal with it?
Front seat modification. Increase thigh support. PetersRedYaris DIY / Maintenance / Service 36 08-22-2018 01:37 PM
front seat room Bigdaddy727705 General Yaris / Vitz Discussion 9 10-30-2013 11:26 AM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
front seat removal/reinstall mark schofield DIY / Maintenance / Service 2 01-25-2009 07:29 PM
FS: Extra Set of Fat Cat Front Bumps Stops Galavoxx Items for Sale by private party 1 07-03-2007 08:58 PM
