Old 08-18-2009, 04:21 PM   #19
taxi142
Drives: Toyota Yaris 2007 4 door
Hey guys i just ordered that part from toyota. man i've been searching for it 4ever THANK YOU THANK YOU ALL!
taxi142 is offline   Reply With Quote
Old 08-18-2009, 04:23 PM   #20
taxi142
OK. I finally found it in the EPC:
It is really called: Panel Sub-Assy, Instrument Cluster Finish, Center
It's part number is: 55405-52790
Here's the picture from the EPC:
just one more question on that would i need to buy the trim kit still?which is this " TA1465B "?
Old 08-18-2009, 04:38 PM   #21
You will still need the trim kit, such as the Scosche TA1465B. It is not pictured, because it is not a Toyota part. The Toyota part that you ordered allows a Toyota radio to be mounted in place of the one you had. The Toyota radios are 20mm wider than standard DIN width, so the Scosche or Metra trim kit fills the gap for mounting a normal double DIN radio. You will also need the harness adapter (Scosche, Metra, etc), if you want to wire your new radio without cutting off the OEM connectors.
Stupid question about installing a radio fmicle In Car Entertainment + Electronics (audio / video / alarm) 6 05-26-2007 04:20 PM
