Old 11-17-2006, 01:19 PM   #1
grimez
grimez's Avatar
Drives: 2007 Yaris
Question about mounting HU
I am planning on getting a DVD capable HU, and adding an in dash screen later. Will this bracket work for doing two seperate single DIN head units?
And if not, is there any bracket out there that will work? Or am I going to have to modify one?
grimez is offline   Reply With Quote
Old 11-17-2006, 02:27 PM   #2
barryware
No... It will not work for two HU's. This is the same bracket I bought (same vendor too). The pocket under the opening is not removable. Call Metra directly (www.metraonline.com), talk to one of their technical support guys. They will tell you the part number of the mounting kit (in your case). Then find someone who carries it. You can not buy from Metra directly unless you are a distributor. Circuit City is a distributor but when I called them, they had none in stock (the one I used) so I got it from E-Bay.
barryware is offline   Reply With Quote
Old 11-17-2006, 03:12 PM   #3
grimez
grimez's Avatar
Drives: 2007 Yaris
Which one did you get... lol.
Old 11-17-2006, 03:23 PM   #4
barryware
That would be the METRA 99-8216!!!
Old 11-17-2006, 04:32 PM   #5
Yaris-TJ
Yaris-TJ's Avatar
Drives: Yaris Sedan ST Barcelona Red
excertp from same ebay page "If you what to install a Double Din in your New Yaris, please check out my Ebay store. Search by Metra model number 95-8202 Thank you.
Yaris-TJ is offline   Reply With Quote
Old 11-17-2006, 04:42 PM   #6
the_saint
50% borikén
the_saint's Avatar
Drives: 06 Mazda5, 90 240sx
Attention to detail my friend....
'06+ Toyota bB
Garson - D.A.D. aero
Zuenglein Dolci wheels
the_saint is offline   Reply With Quote
Old 11-17-2006, 05:06 PM   #7
grimez
grimez's Avatar
Drives: 2007 Yaris
I assumed that he had the same problem, not that he was just giving advice... just a misunderstanding and a lil confusion on my end
I am not looking for a bracket to install a single 2-DIN unit, I am looking for a bracket that will eliminate the gap between two single 1-DIN units. I don't know if my previous posts made that clear (being an engineer, I naturally have a hard time communicating with others).
Old 11-17-2006, 05:17 PM   #8
barryware
Dude...I knew you were teasing. Call Metra and tell them what you want to do. If they have a mounting kit available, you can get the part number and then look for it.
I understood what you are trying to do. The 95-8202 is not what you want.
Old 11-17-2006, 05:58 PM   #9
bigsky2
Cousin Vitz
bigsky2's Avatar
If you are installing two head units, you will be peforming an ISO mount which would require some special hardware.
I have seen an install of two head units using parts of the 95-8202 kit, and other odds and ends. The brackets for the 95-8202 kit would be used to mount the sleeve/cage, and you use some other hardware to mount the two head units to the cage.
Old 11-18-2006, 01:31 AM   #10
spkrman
Drives: 1
i'd just fab something up for this.
Old 11-18-2006, 04:35 AM   #11
johnnyfive
johnnyfive's Avatar
the metra kit that is made for double din headunit, has a stacked single din provision. that is the kit you want, sorry i do not have the part number ;)
johnnyfive is offline   Reply With Quote
Old 11-18-2006, 07:59 AM   #12
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Not two head units, but I used the metra double DIN kit for this install and put a length of black adhesive foam tape at the seams:
Old 11-18-2006, 08:16 PM   #13
Black Yaris
der Zeck
Black Yaris's Avatar
Violin, are those 2 drawers above your head unit?
Old 11-18-2006, 08:33 PM   #14
That's his cupholders so he can always have 3 cans of brew at close reach
I've seen the same kind of getup here, but with 3 or 4 sliding trays for keeping CDs in.
Question on deposit SimplyYaris New YARIS Purchase Forum 16 11-15-2006 06:20 PM
Question on Yaris wheels featherz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-17-2006 10:27 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
Mounting depth Yar In Car Entertainment + Electronics (audio / video / alarm) 4 09-12-2006 01:05 AM
Simple Question...Head Unit...(Dont flame me!! :P) hasher22 In Car Entertainment + Electronics (audio / video / alarm) 2 09-06-2006 01:35 PM
