Old 02-04-2009, 10:36 PM   #91
Marfulion
Drives: 2008 Yaris Sedan
Performance wise, what would be the best tire, rim, etc size for a yaris puttin out about 150hp? thanks
Marfulion is offline   Reply With Quote
Old 02-22-2009, 01:39 AM   #92
GrayFox
Drives: 2009 5 Door YRS
Here is another good calculator, just in case you found the other ones a bit too confusing. This is also good to compare stock size with any aftermarket size.
http://www.miata.net/garage/tirecalc.html
GrayFox is offline   Reply With Quote
Old 03-05-2009, 09:11 PM   #93
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
Subscribed. Thanks!
Saggio is offline   Reply With Quote
Old 03-17-2009, 12:23 AM   #94
tonyg
Drives: yaris
those TRD wheels make no sense. With the TRD springs and the TRD Option 18x7.5, ET42, 215/35/18 = 23.9
can someone explain to me how these wouldnt rub big time? If 205 rubs on stock wheels, how is 215 with a 42 offset not going to rub?
tonyg is offline   Reply With Quote
Old 04-07-2009, 01:19 AM   #95
pixitha
Pixitha
Does anyone know the exact dimensions of this wheel: http://www.trdsparks.com/displaypart...&parts_id=1101
I have the standard steel wheel black and ugly with ghetto hubcaps and wan't something else...
I have 185/60/15 on the wheels right now and want to make sure the Toyota alloy wheels from TRD will still work with those and such?
thanks!
-pix
pixitha is offline   Reply With Quote
Old 04-16-2009, 09:04 AM   #96
goku87
goku87's Avatar
Drives: Black HB
Exclamation Should not the lug pattern be at the beginning of this post?
4x100
goku87 is offline   Reply With Quote
Old 05-01-2009, 12:29 PM   #97
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
from a performance and wallet stand point, what is a recommended setup for standard springs and 1.5" dropped? I keep finding 15" x 6.5" is about as large without getting too heavy (i was hoping to go as light or lighter than stock, if that's possible while still going slightly taller and much wider). assuming 15x6.5, is 185/55 a good fit, or are the tires too skinny for the rim?
Old 05-01-2009, 01:50 PM   #98
scape
scape's Avatar
now that i'm looking around 205/50/15 looks more appealing on a 15x6.5
Old 05-01-2009, 03:43 PM   #99
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
I have 205/50/15!
CLA 250, 4MATIC
Old 05-25-2009, 03:56 PM   #100
scape
scape's Avatar
Staggered fitments:
2. Staggered tyre widths are less common, especially on front wheel drive cars. These applications even out front to rear fitment. They are not recommended for the track, but as an appearance option they are safe under normal driving conditions. Staggered tyre widths preclude tyre rotation.
Example: FR 205/55/15//RR 225/50/15
Example: FR 205/50/16//RR 215/50/16
Example: FR 205/40/17//RR 215/40/17
why are staggered tire sizes not recommended for the yaris? too much understeer as a result?
Old 05-26-2009, 02:11 AM   #101
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I have 205/50/15!
+1
Although 205/55/15 is still perfectly acceptable if you'd rather fill out the wells a bit more. I'm very happy with my setup though.
Old 06-16-2009, 10:39 PM   #102
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
Thanks for the info!
id3379 is offline   Reply With Quote
Old 06-16-2009, 10:54 PM   #103
Black Yaris
der Zeck
Black Yaris's Avatar
just a FYI I am running 205/50R17's
I had too many problems with Toledo roads and 205/40R17's
the 50 series looks, fits and rides awesome
Old 06-17-2009, 12:15 AM   #104
kimona
kimona's Avatar
Drives: 2014 White VITZ
Are you talking about the Toaster or the Yaris?
Old 06-19-2009, 12:01 AM   #105
liyux2k
liyux2k's Avatar
Drives: Vios
"15x5.5, ET45, 185/60/15 = 23.7" is that offset for the stock black steel rims and hubcaps or the stock alloys? or both?
liyux2k is offline   Reply With Quote
Old 06-19-2009, 07:22 AM   #106
kimona
kimona's Avatar
OEM alloy wheel/tyre specs.
Old 08-20-2009, 11:11 AM   #107
zarniko
Drives: liftback
which tire should i use to put xxr513 15x7 with the DF210 springs so that it wont rub?..or is it not possible with the 7in width???
zarniko is offline   Reply With Quote
Old 08-26-2009, 12:17 AM   #108
hafeez
Drives: 2007 Silver Toyota Yaris Sedan
hey i have a question;
my 07 sedan is lowered on megan springs which is about a 1.5" all around. if i'm using my stock alloy wheels what would you recommend for tire size? for no rubbing?
+1
hafeez is offline   Reply With Quote
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 98 02-18-2024 06:45 AM
