Old 11-20-2006, 04:11 PM   #1
gravylegs
Drives: 2007 Yaris Liftback RS
Pulling wires through the Yaris
This post is half question, half warning.
Yesterday I finally got around to pulling the power, RCA, and remote turn on wires from the battery/deck. The whole operation was fairly simple.
I pulled my power wire through an existing grommit hole on the passenger side floor. You pull back the carpet, then pull back the second carpet, then lift out the styrofoam floor piece (which I was suprised to find!), and there is a tube running from what looks like the HVAC right through the floor. I think it is an air intake. I put the wire outside of the grommit, and then wedged the grommit back into place holding the power wire snug. This was the only easily accessible hole in the firewall that I could find. My question here are: What is this tube? If it is an air intake, it is sorta scary that it is sucking my heating/cooling air in from the engine bay!
From here I pulled the wire over to the passenger side (pulled off the trim from the kick panel to the plastic panel that divides the front from the back) and ran it along the side of the car all the way through to the lift. My questions here: putting the trim back on the bottom of the door is really difficult! I had a REALLY hard time getting the carpet to hook back onto the clips that hold it in place, and then when putting the trim back on it simply will not clip back on. It stays in place nicely, but it definitely isn't right.
Any suggestions?
Stereo sounds sweet now...
Oh, and the warning part is "be careful when trying to put back the carpet and trim"
gravylegs is offline   Reply With Quote
Old 11-20-2006, 04:40 PM   #2
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
You ran the wire between the metal and the grommet?
Bad idea !
you are far better of drilling a hole for the wire or using an existing grommet with enough spce to poke another hole through.
The early bird gets the worm, but the second mouse gets the cheese.
07WYarisRS is offline   Reply With Quote
Old 11-20-2006, 04:40 PM   #3
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
From other post and readings I believe that the hose is used as an A/C drip hose (to lazy to look through the manual).
As far as the trim goes, double check and make sure that none of the "snaps" arent broken or bent. and try sliding it forward or backward to make sure that it is indeed in the right place
will work for parts
vodkalush is offline   Reply With Quote
Old 11-20-2006, 08:50 PM   #4
spkrman
Drives: 1
best way is to drill a hole right next to the AC drain hose exit. Mine is temporarily jammed in there with the hose until I can find, or just break down and buy another unibit. When running 2/0ga wire it gets a little trickier hehe.
Old 11-22-2006, 10:37 PM   #5
atebit
Drives: 07 Yaris Sedan
Any suggestions for wire-pulling access points for the sedan (from front to rear)?
Also might be looking for a way to snake a few wires down from the area of the map lights to the dash area, without disturbing the side airbags in the pillars.
atebit is offline   Reply With Quote
Old 11-23-2006, 03:46 AM   #6
spkrman
Drives: 1
Originally Posted by bigsky2
What are you powering there? Some Zapco competition amps?!
2/0AWG is good stuff, but might be overkill if your total system power is less than 1000w RMS.
But yes, if you are running 4AWG or larger wire, it might be ideal to just drill a new hole next to the AC Drain hose exit.
I was able to cut out a small pie portion of the existing gromet from the drain hose and use that empty area to plug in the 4AWG wire.
That 2/0ga wire has been in every one of this setups:
http://www.yarisworld.com/forums/sho...8235#post38235
It will get plenty use in the yaris... and there will likely be a few more runs of it too :)
Old 11-23-2006, 11:28 AM   #7
Yaris-TJ
Yaris-TJ's Avatar
Drives: Yaris Sedan ST Barcelona Red
[QUOTE=bigsky2]I didn't have too many problems running wires through the sides of my Yaris.
Mind if I ask if you have a 5DR or 3DR?
The 5DR is easier to run as there are scuff guards for both the front and rear doors, which makes it much easier to route and keep in place with electrical tape or some light adhesive.
But I actually ran the power wire and remote turn on wire through the center of the hatchback.
QUOTE]
Silly question, did you actually had to remove both front seats?
Yaris-TJ is offline   Reply With Quote
Old 11-23-2006, 11:32 AM   #8
Yaris-TJ
Yaris-TJ's Avatar
The biggest pain is running wires through the boots of each door.
If anyone is planning on rewiring the speaker wires, I suggest using 16AWG twisted speaker wire so that you only have to run one wire per door.
If you must use a larger gauge like 14, I strongly suggest ultra flat wire like the Audison UF series.
will the cutting-hanger solution work or make it easier?
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
