Old 09-01-2009, 11:57 AM   #19
Here's one for $25:
http://cgi.ebay.com/ebaymotors/scion...Q5fAccessories
Old 09-01-2009, 12:00 PM   #20
nick.dollimount
Yaris = <3
nick.dollimount's Avatar
Drives: '08 Sedan - Flint Mica
Nice! I'm very excited to add this in =D I like the idea of the little 4-way switch more than the stalk though. Will look much cleaner =D **stoked**
..:'; Nick ;':..
2008 Yaris Sedan - Flint Mica
Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter
nick.dollimount is offline   Reply With Quote
Old 09-01-2009, 12:09 PM   #21
I wonder if it is mechanically limited to the 90 degree positions or if you can accidentally press two switches at the same time with a 45 degree motion?
Old 09-01-2009, 12:19 PM   #22
nick.dollimount
Yaris = <3
From the specs below, I would guess that it's only one at a time? I'll have to make sure about that when I'm going to check out that parts store. I'm sure if it closed two connections at once, that would be bad?
Technical/Catalog Information 500-526
Vendor APEM Components
Category Switches
Type Navigation Switch, PCB Mount
Actuator Type 4-Way Selector
Switch Function 2 Axis
Output Mechanical Switch
Operating Force 100gf
Contact Rating @ Voltage 0.05A @ 24VDC
Termination Style PC Pin
Lead Free Status Lead Free
RoHS Status RoHS Compliant
Other Names 500 526
500526
679 2289 ND
6792289ND
679-2289
..:'; Nick ;':..
Old 09-01-2009, 12:24 PM   #23
I noticed in the PDF that it says actuation at 90 degree positions, which hopefully means that only one can be closed at a time. If more than one could be, then you could be trying to bump it up with the + and accidentally hit off.
Old 09-01-2009, 12:39 PM   #24
nick.dollimount
Yaris = <3
Yeah, that would be counter productive :P
..:'; Nick ;':..
Old 09-01-2009, 01:31 PM   #25
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
Wow, awesome job on the write-up man. I wish I could have done it, but I'm not that organized :) and flutie98...CTScott put together an LED module (that I still have yet to install...sorry scott) :( But I will get to it soon and do pics and a small write up on it so he can sell em to you guys and you can install them.
My Car Rules!
nickhjort is offline   Reply With Quote
Old 09-01-2009, 01:45 PM   #26
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Thank you, Vince87 and CTScott. This is my next project.
Old 09-04-2009, 09:49 AM   #27
nick.dollimount
Yaris = <3
Woot! My clutch switch is in the shop today; picking it up tomorrow. I'll probably do this up on Sunday, as long as I can get the switch and resistors on Sunday.
..:'; Nick ;':..
Old 09-05-2009, 01:18 AM   #28
yaris-me
Learn to Relax
I couldn't find the resistors 290 and 340. Are those the correct values? They also had 1/4, 1/2 and 1 watt resistors. Which wattage?
Old 09-05-2009, 01:28 AM   #29
It's actually 240 and 390.
You can use any value within these ranges:
216 to 264 ohms for one between resume and on/off
351 to 426 ohms for the one between set and resume
819 to 1001 ohms for the one between set and cancel
For wattage, 1/8 or 1/4 watt is fine.
Old 09-05-2009, 12:05 PM   #30
yaris-me
Learn to Relax
Thanks!
Old 09-06-2009, 02:09 PM   #31
toocool79
Drives: 2009 YARIS 3DR
Just installed the factory cruise parts. I used all new parts from TRDSPARKS, Very easy install. On my 09 3dr. liftback w/manual trans. Yes the icons in the cluster work also!.THANKS to all that provided part #s and insite.
toocool79 is offline   Reply With Quote
Old 09-08-2009, 07:29 PM   #32
Vince87
Drives: 2007 2DR Yaris
Hey just a quick question for you guys: has anyone done it on a 2006 yaris? I thought it was still the Echo, hence I wrote in the DIY that it was for the 07-08...
Vince87 is offline   Reply With Quote
Old 09-08-2009, 08:59 PM   #33
06 should be the same as 07-08. Echos ended in 05. Canada got the Yaris in 06, and the US in 07.
Old 09-12-2009, 10:23 PM   #34
opt101
Drives: 2007 Toyota Yaris 2dr
Hi, Does anyone have the radio shack resistor part numbers by chance... Would love to try this mod, I just got my 2007 yaris yesterday, and no cruise is a bummer for my 60 mile commute, thanks in advance!
opt101 is offline   Reply With Quote
Old 09-12-2009, 10:57 PM   #35
julienrl
Drives: 2007 yaris
radioshack usually sells reisitors in packs, not individually. I used a 300 resistor pack (3 or 4$) and just combined the ones I needed to get the appropriate resistance, but this is long and requires a multimeter or reading all teh color codes (even worse). Your best bet is Digikey.
julienrl is offline   Reply With Quote
Old 09-12-2009, 10:59 PM   #36
If you buy the 500 piece "value pack" for $12.99 you get an assortment that includes 220 ohms, 390 ohms, and 1K ohms.
If you buy them as the 5 packs for $0.99 each, you can get 220 ohms (271-011) and 1K ohms (271-004), but not something in the range of 351 to 426 ohms. Although, You can buy a pack of 150 ohm resistors (271-010) and use one of those in series with one of the 220 ohm ones to get 370 ohms.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 01:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
