Old 09-25-2009, 02:23 AM   #1
petronas
Drives: 07 Toyota Yaris
Boot Door Sensor?
My Mrs. has an 07 Yaris and because it got into a rear end crash the boot door sensor is always on.
I was wondering if there was a fuse or wire I would take out to disable it.
I'm also getting an an aftermarket alarm system installed so I wanted to disable the sensor in case there was a conflict in the alarm system with the door sensor.
petronas is offline   Reply With Quote
Old 09-25-2009, 09:19 AM   #2
The sensor is within the lock assembly. You'll notice a wire going into it (hardwired without a connector). If you follow that wire a short distance, you'll come to blue two pin connector. If you disconnect it the light on the cluster will go out.
Redline shift boot PHXDEMON Cosmetic Modifications (Exterior/Interior) 27 10-01-2009 12:14 PM
Redline Shift Boot for 09? MGargano Cosmetic Modifications (Exterior/Interior) 16 06-03-2009 03:12 PM
Shift boot and Handbrake Boot. 1NZYaris1 Cosmetic Modifications (Exterior/Interior) 33 05-05-2009 10:21 PM
GTA GB for 5spd leather shift boot uncleyaris Canada 0 10-19-2008 11:06 PM
