Old 09-27-2009, 04:43 AM   #1
charleschia1986
charleschia1986's Avatar
Drives: Yaris RUSH HatchBack
Amplifier Remote (turn-on)
hi guys, i tried to connect my amplifier (remote terminal) to PIN 8 (Antenna Power) which is shown in the picture. and yet it only works when i m listening to radio, once i switch my radio to AUX mode thn it will turn off my amplifier again. may i know which pin can i use instead?
thanks for ya helps...
charleschia1986 is offline   Reply With Quote
Old 09-27-2009, 09:20 AM   #2
Unfortunately the power antenna wire is unpowered when playing CDs.
You can use D10 - Pin 3 instead. It is an ACC switched wire, so the amp will be powered even when the radio is not on, but it will turn off with the car.
Old 09-27-2009, 09:36 PM   #3
charleschia1986
thanks,
do u know what color is the ACC switch? other than that is there any pin that i can use so that my amp will turn off when i turn off my player?
regards.
Old 09-27-2009, 09:51 PM   #4
The ACC wire is a gray wire.
On the OEM HU there's no pin that will work for the amp turn on (with both radio and CD) and will kill the amp with the HU.
Old 09-27-2009, 09:58 PM   #5
charleschia1986
thanks CT
does your ACC refer to the Radio Ignition and which is gray in color?
Old 09-27-2009, 10:22 PM   #6
Yes. ACC is the ignition switched power wire.
Old 09-27-2009, 10:32 PM   #7
charleschia1986
thanks for your super fast reply CT,
i tried the ACC wire already and tested with a multimeter. the output voltage of this wire give a voltage of 14V + when my car is ignited. is that alrite to run more than 12V into the Amp?
and yet can i actually use the radio battery wire?
regards.
Old 09-27-2009, 10:46 PM   #8
goku87
goku87's Avatar
Drives: Black HB
yes.
and yes.
goku87 is offline   Reply With Quote
Old 09-27-2009, 10:47 PM   #9
The 14V into the amp is fine.
The remote turn on is a low power circuit, so using that wire is fine.
Old 09-28-2009, 12:44 AM   #10
charleschia1986
Thank guys....
i have FINALLY done installing my subwoofer and everything works fine.
thanks for all the advices.
cheers.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
Power door lock keyless entry and remote start rizaydog In Car Entertainment + Electronics (audio / video / alarm) 10 07-20-2009 04:14 PM
