Old 09-27-2009, 11:35 AM   #37
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
and the money spent "upgrading" cams ? $1000.. gains? i'd wager less than 20hp..
again, not very cheap.
really dont think its gonna cost $1000 for cams for this car. I cant imagine anyway it would. It most $800.
Originally Posted by scape View Post
well the real questions are how much do you want to spend in total (less than 2k$ i gather) and how much power do you want to have (about 120hp i gather)...
this guy has bought some new internals: http://yarisworld.com/forums/showthr...pistons&page=3
mostly I'd be interested in is those rods, they look substantial (though I think they lower the compression), I'd also be interested to see if anyone adapted the prius pistons (http://www.yarisworld.com/forums/sho...rius+internals) to a yaris, they possibly handle a greater compression ratio I believe or if anyone found some new head gaskets.
if you did increase compression, a new camshaft would most likely be required, or atleast adjust your current one to properly reflect this.
with all of this, you'd REALLY want to plan this out and make sure the components are highquality, stronger than original, lighter than original, and made to greater tolerances than original; then find a way to tune the whole thing (probably the most intensive and important portion of this whole thing)...to save money you'd want to probably do the install or find a friend to install the components.
as well, this would only really work on 2 main aspects of the engine (how much more energy it can extract from gas using a higher combustion point, and possibly how much faster your engine can cycle-- something I would not venture on personally as much more work needs to be done).
other than that, find a way to drop weight significantly while still catering to your lifestyle: http://www.yarisworld.com/forums/sho...ght+reductions
a drop in 100lbs (dead,non-rotating) weight would be about a +4hp equivalence...
I ignored all of the first of your post as its clear you didnt read mine where i stated that i would rather not get into the engine and opted for other means.
Look at my dyno again i need about 8whp to make it to 120. I kno this can be done without getting into the engine. Just asking for some more ideas.
So plz no more talk of how expensive it is to go N/A or these over the top engine builds. Keep its simple bolt ons. U have my post with my dyno and mods. Give me something i haven't thought about.
I like the weight reduction idea. Will have to see if i can manage that.
Yoda is offline   Reply With Quote
Old 09-27-2009, 02:00 PM   #38
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
special sauce? i believe that will work...
to be honest, I re-read this entire thread and you never mentioned not wanting to get inside the engine; all I pointed out was that to go further you might need to crack her open and do real work, not bolt-ons.
I don't think there is too much more you can do without getting in there and doing internal work; weight reduction is by far the most economical choice (to a limit).
how heavy are your bolt-ons added up?
do they make up for the additional weight in power? i have a feeling they do partially, a dyno does not take into account the weight of the vehicle (to my knowledge) and thus you should think about that, 23 lbs for every hp.
your dyno says 111hp which is great... but without a new camshaft or atleast ecu work I don't know if there is much left to do...
good luck
Old 09-27-2009, 03:38 PM   #39
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
are you installing them yourself?
Originally Posted by xnamerxx
you nailed it sir.
Old 09-27-2009, 06:21 PM   #40
Yoda
Yoda's Avatar
yes
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 11:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 12:59 PM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 01:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-27-2007 12:18 AM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 09:45 PM
