Old 12-02-2006, 12:09 PM   #1
dngz
dngz's Avatar
Drives: black yaris sedan
Rear Strut Bar for Sedan?
Is there a rear strut bar for the sedan?? and where exactly does it go??
dngz is offline   Reply With Quote
Old 12-02-2006, 12:38 PM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
How and where do you access the top bolt for the rear shocks? Thats where the bar will mount.. in a Liftback its very simple. Remove both screen looking covers on each side, look down, and there is the top mounting point for the shocks. Cuts down on trunk space keep in mind.
Old 12-02-2006, 06:21 PM   #3
fat45s
Drives: Yaris Sedan YRS - Black Mica
to get to the top bolt for the rear shocks, you just have to pull of the plastic/cloth covering on the sides of the boot. and behind that youll find them.
fat45s is offline   Reply With Quote
Old 12-02-2006, 06:34 PM   #4
Chris07LB
Chris07LB's Avatar
Ok, so that means then, its not as easy to install for the sedans.
Is it in a place where carpet would need to be cut/modified to get a bar on top of?
Search for rear strut bar here, and you will see what Im getting at... picture was posted on a Liftback, so by looking at that, maybe you can better judge how it would or would not fit on a sedan.
Could be the center point of each shock is further distance from the LB's, so their bar migght not even reach.
Just tossing around ideas....
Old 12-02-2006, 09:19 PM   #5
fat45s
ive just doubled checked.
my bad. i forgot that we were talking about a Yaris not a skyline.
With my old skyline, i just had to pull back the carpet and there they were.. but the yaris, it has a completely different suspension system. so theres no way that you could possibly do it. unless someone finds a way.
sorry to put any ones hopes up.
Old 12-03-2006, 08:53 AM   #6
Chris07LB
Chris07LB's Avatar
On to the next person that can actually pop a trunk an look....... at a Y-A-R-I-S that is!
Old 12-03-2006, 10:42 AM   #7
dngz
dngz's Avatar
yea, i tried looking behind the carpet thing in the trunk, not much luck.. but i didnt completely take it off.. next time i will! There has to be a way to access the rear shocks!
Old 12-03-2006, 10:45 AM   #8
Chris07LB
Chris07LB's Avatar
Try just above the wheel well arches... or look to see where the shocks are under the car, and follow that up to about where inside the car...
Old 12-10-2006, 03:50 PM   #9
johnnyfive
johnnyfive's Avatar
i know im a little slow here...but finnaly temps were above freezing, and not all of us have garage space :)
but it apears you would need to do some metal work to put the bar from t he hatch in the sedan...the same mounts are there, but there is some sort of support on the inside of it, looks like some sort of rear deck support.
i wouldnt imagin any loss of structeral stability with a small hole for the bar, but would definetly need more work than just cutting a hold in some carpet :)
johnnyfive is offline   Reply With Quote
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 06:43 PM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 02-22-2007 11:08 AM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM Performance Modifications 2 10-07-2006 02:26 AM
c one motorsport performance bars badhabitz Performance Modifications 17 08-23-2006 10:31 PM
