Old 11-11-2008, 05:32 PM   #19
Treyz
~ ambient one ~
Treyz's Avatar
Honestly, I would have done it from the inside.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 11-11-2008, 05:38 PM   #20
CKaelin
CKaelin's Avatar
Drives: 2008 Yaris LB 5 speed
Love to see it. Not much room to work in there?
My other ride's a Gixxer!
CKaelin is offline   Reply With Quote
Old 11-11-2008, 06:20 PM   #21
Treyz
~ ambient one ~
Treyz's Avatar
Of course there is. The front bumper comes off easily. Then again, it might be easier with the Micro Image Grill. Only thing that it might touch up against is the horn.
AMBIENTLIFESTYLE
Micro Image
Old 11-11-2008, 06:50 PM   #22
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
There can be hot winter days where it would be best to have the grill cover off. Having it on the inside would be a real pain.
Old 12-30-2008, 11:24 AM   #23
CKaelin
CKaelin's Avatar
So I stop at my local mechanic/gas station on the way to work this morning. I'm topping of my tires with air and my mechanic friend, Vin comes over. "Hey Cliff, what's up with the grill cover?" I say.. "To help warm the engine up quicker and keep it warm to improve mpgs by running an warm engine." He goes on to tell me it's going to interfear with sensors and he thinks it is a bad idea. It can possibley do more damage then could ever be worth gaining acouple mpgs..
I took it off...
Old 12-30-2008, 12:03 PM   #24
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Dot Dot Dot?
I could only think of at least two sensors, the one(s) in the air intake, mainly the MAF and the coolant sensor. The ones in the intake are for intake air temp and the one for the coolant is for the coolant temp (obvious statement).
Did your friend elaborate?
Old 12-30-2008, 04:57 PM   #25
yarswiss
Albino truck smasher
yarswiss's Avatar
Drives: '07 Yaris LB Auto
I've had a near-full upper grill block on my car for the past 5 months, and no damage has occurred as a result of it. I've even had a complete upper-and-lower grill block for a month, during the hot season here in California (90-110F) and the highest temperatures I recorded from the Scangauge was 208F. I called Toyota to make sure, and the 208 is the temperature at which the engine fan starts up, and it can go all the way to 280F before the engine will shut itself off to prevent overheating.
So I can assure you, having an upper grill block during the winter should not cause any damage to either sensors or internals.
Here's my block, btw:
yarswiss is offline   Reply With Quote
Old 10-12-2009, 05:51 PM   #26
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
anybody have any more pics of the grill block/dam they made? I'm wanting to do an external one (for simplicity of installation/removal) but am not a big fan of most of the installs i've seen so far (I don't want to be embarrassed to drive my car around).
Old 10-12-2009, 06:31 PM   #27
roadrunner
Yaris Hypermiler
roadrunner's Avatar
Drives: 2007 Silver Liftback
I have been using black floor molding for a few years as a grille block.
roadrunner is offline   Reply With Quote
Old 10-13-2009, 08:54 AM   #28
Woody_Woodchuck
Drives: 2008 Yaris LB 5M
Mine is similar to the OP’s block only mine is coroplast and tied with 12 gauge copper wire. Sure the wire sticks out but I’m not into looks I’m into function. Full upper block caused absolutely no issues with overheating or any sensors that I am aware of. I took it off when regular morning temps were in the 70’s. I put it on as a test on an 80 F commute morning and had no issues with overheating.
I also noted by putting it on the outside as level with the body as possible it seemed to give me a slight boost in aero, I noticed my glides were longer than without it. Having that gaping hole right in front is a killer while making it as smooth as possible is a help. The lower grill I did not block last year and this year I will be experimenting with a 50% block (either side) to start. My thinking is that if I am running easy there is no reason why the fan and a limited amount of opening can not cool the engine.
I don’t remember the numbers but there was a gain in FE with the upper block versus without it.
Lifetime log
Woody_Woodchuck is offline   Reply With Quote
Old 10-13-2009, 09:32 AM   #29
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
I also noted by putting it on the outside as levtel with the body as possible it seemed to give me a slight boost in aero, I noticed my glides were longer than without it.
Woody,
What is coroplast and how much is it? I'm going to do the block I'm just trying to figure out what to use.
Thanks,
R2
Update-I Googled coroplast and bought half a sheet from a local sign shop. Neat stuff-looks like the perfect material for the job. Thanks!
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 10-13-2009, 09:46 AM   #30
AND189
Drives: 2
ha h if i did that to mine in australia i wouldnt leave the driveway
AND189 is offline   Reply With Quote
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 10:33 PM
Grille Thread.. Blenjar Cosmetic Modifications (Exterior/Interior) 40 11-14-2010 04:26 AM
New grille or not free297 Cosmetic Modifications (Exterior/Interior) 27 11-14-2010 04:21 AM
Need help, removing grill, adding new one drbilal DIY / Maintenance / Service 4 10-29-2008 10:11 PM
DIY: Yaris Hatch grill block/air dam yarswiss DIY / Maintenance / Service 0 10-26-2008 07:52 PM
