![]() Drives: Toyota Yaris 1.3 Xli 2008 Join Date: Apr 2009
Iam planning to install a set of TEIN's S-Tech on my 2009 Yaris sedan but I don't know if Iam going to have rubbing problems with my 205/50/16 tires,(offset 42,american racing Haze rims)...should I have to go down to 205/45/16 tires??I live in Peru so the roads are not that good.
Thanks, all ideas are welcome Sebastian |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
You should be fine as long as you drive slower with that setup.
It would also help if you did a strut upgrade to minimize the bouncing, which should eliminate what's left of the rubbing issue.
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
If it is of any help, I'm on s techs and stock 15s w/ stock tires and stock shocks and I have only rubbed on the liner once or twice very lightly at like 50 mph on a big sharp dip.
Idk how much this really helps you but just thought I'd share my experience.... |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
I use the Tanabe DF210 lowering springs on 205/50/16 and I rub usually while pulling u-turns at low speeds.
After the advice probably I should go to down to 45īs to avoid rubbing issues...thanks for the help
I'm running on 205/45/17. You will be fine. Other then the obvious speed bumps, sharp dips no problems here.
| 07+ Yaris Tein Springs/Suspension | CorSport | CorSport | 0 | 07-09-2009 01:18 PM |
| WTB: Tein S. Tech rear springs | jkuchta | Willing to Buy by private party | 4 | 03-06-2009 02:00 PM |
| Springs - Tanabe DF210 or Tein S Tech | andylai2k | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 06-10-2007 09:22 PM |
