What kind of car is that?
Quicker Decelertaion
I'm not sure if there is already a thread on this (i had no luck finding one) but when you will notice when the car is sitting still or in gear that when you rev the engine the deceleration is very slow compared to most cars. What are some step you can take to change that?
I think its possible due to the drive by wire system electronic throttle. When you snap it on a conventional system the cable snaps open the butterfly and the spring quickly snaps it shut if you take your foot immediately off the gas.
On our system its controlled by a computer and electronic motor. Could be the motor can not react as quickly within a split second and gradually closes back down the butterfly. |
resident senior
A lightened flywheel will solve that problem , but will create others
Apexing Egg!!
like stalling when you flip it into neutral. my car does this all the time now!
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
Only Happy When it Rains
really? that stinks.
Colin Chapman disciple |
Apexing Egg!!
its not a big deal. if rolling, throw it back in gear and if stopped, just start it haha
i had fidanza in my xrs and never had a stalling problem.....6.5lbs vs 13lb stock....so super light too
but lightweight pulleys and flywheel will help the engine rev up and down more quickly
Are these the only possibilities?
Lurker supreme!
Drives: old and boosted! Join Date: Nov 2006
Hack the signal to the throttle body?
2006 Red Blitzed RS 5-door |
★weeaboo★
Actually, it would be possible to use a 1ZZ throttle body. My idle went up 200 rpms when I installed mine (and hasn't gone away), which would help.
i have a corolla tb is that what you mean?
the deceleration didnt change when i swapped it.
#12 | |
i have the lightweight crank pulley would changing the others really help?
Apexing Egg!!
why do you want to make the engine stop spinning faster??
the only reason i can think of would be because that means it spins more easily while accelerating? thats kind of a backwords way to look at an improvement in throttle response though. to improve throttle response, in general there are two things you can do. lighten the parts that rotate (ie pulleys, flywheel, remove things like AC) or improve the flow (individual throttle bodies, header). i think timing has a small influence, but its probably minimal. so if you improve throttle response, you will improve your engine slowing down thing, also increasing your ability to stall the car lol
#14 |
#15 |
It is more of preference thing than it is a performance thing
i like when it snaps back fast because it is what i'm used to the other cars i have owned have all snapped back much quicker and its not as if every car i have owned has been a performance car (geo metro, dodge neon, vw gti mkII) as an econo car i know it will have some quirks but this is just one i don't like id like to fix it somehow :)
#16 |
![]() ![]() ![]() Drives: 08 liftback 5spd Join Date: Oct 2008
hmm. friction brake on the serp belt? if anyone (other than ctscott, he's busy making yargauges!) has the ability to read the signal to the solenoid that controls the throttle body it coud at least be confirmed it's a bastard child of fancy programming and our econobox.
another option is following in garms footsteps---fancy gas pedals and cable system! standalone ecu? i'd say it's in the software... |
#17 |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
I noticed this back in the day when emission controlled vehicles became the normal and was told that a slower/controlled RPM drop reduced pollution. My guess is that todays cars rev down slowly for the same reason.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
#18 |
No problem at all with stalling and a lightweight flywheel here. (and that includes before I added FI). Don't let these guys warn you off of that idea. Excellent way to open up throttle response, both directions.
| BP Ultimate means engine quicker warm-up? | lh59 | DIY / Maintenance / Service | 45 | 12-18-2008 02:37 AM |
