Old 12-26-2009, 07:46 PM   #1
birdman
Drives: '08 Blazing Blue Yaris LB
HELP, WONT START!!
My car makes the clicking sound but wont start. Headlights are dim too. I take very good care of it and it's garaged too. Only 16k miles and it's an automatic. Battery looks filled and my engine compartment is very clean. The little grey cover thingy on the wired end of the starter is a little wiggly but thats all I can see. Any ideas? Thanks
birdman is offline   Reply With Quote
Old 12-26-2009, 07:48 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Usually that means a run down battery. If you've got jumper cables and another battery at hand, try jumping it, or try hooking a charger to it overnight and see what happens. If neither works, you're in the market for a battery.
Old 12-26-2009, 08:05 PM   #3
Sidicas
Drives: 2010 Toyota Yaris Hatchback
Yup, either the battery is dead or the battery is bad..
If it's below freezing in your garage, take your battery inside and hook it up to a car battery charger.. If it's dead and it gets cold, it WILL freeze and then you won't be able to charge it.
If it's not so bad, you might be able to charge it while it's in the car..
Sidicas is offline   Reply With Quote
Old 12-26-2009, 09:31 PM   #4
YarisSedan
Drives: 08 Yaris Sedan
Sounds like the battery is weak.
Old 12-26-2009, 10:20 PM   #5
Kal-El
Kal-El's Avatar
Yeah, sometimes batteries go prematurely. A cell may go. May be able to replace it under warranty. Otherwise, the Yaris always starts.
Old 12-26-2009, 10:44 PM   #6
birdman
Funny thing is it nearly did the same thing a few months ago when it barely had enough juice to start the car. The car has been starting perfectly since. I ended up getting a jump tonight and drove it for 1/2 an hour before I parked it at a store. When I got back in it started right up and once again until I returned home for the night. I cant imagine what's drawing down the battery enough so that it only does this occasionally? It's got plenty of warranty left.
Old 12-27-2009, 12:21 AM   #7
Ryu
Little tip I can offer is to turn off everything that needs electricity before you turn on your engine, ie stereo or some other accessory you are using it earlier, it will cause less drain for the battery to start the car.
Like others mention, sounds like the battery is weak.
Old 12-27-2009, 12:22 AM   #8
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
check you have not left the internal light on , or the rear hatch might not be closed properly , leaving that light on .
Old 12-27-2009, 01:27 AM   #9
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
The negative terminal on the batt will get corroded and will cause battery not to charge, happened to me this morning, cleaned it worked fine. Before it would need a jump everytime to start.
Check out my Build thread:
Old 12-27-2009, 01:27 AM   #10
Kal-El
Kal-El's Avatar
A shop can run a quick test on itand even tell you what the issue is. To me, it sound's like a dead cell (which they can determine). Car batteries generally have 6 cells. If one dies, you begin to see this inconsistency where most of the time it's fine, then suddenly it's weak. Once cold weather hits though, expect it to be consistently dead.
This just happened for me recently. My '07, at about 65,000 miles, needed a battery replacement early (should last longer than 4 years). It was checked earlier at under 60K and I was told that I had a dead cell even though I hadn't noticed any issues. It was summer however and by the time winter approached, jump starting started to be required which gets annoying really quick.
Headed to Wal*Mart and got a battery for a cool $65 and threw it in myself in 3 minutes.
Old 12-27-2009, 02:10 AM   #11
YarisSedan
Kinda weird lots of people have been having battery issues lately. When i get in to work on monday im going to load test my battery and see what the total amperage is left after driving for a year. Maybe these only have a 2 year lifespan.
Looks like its a good time for you to upgrade to a lightweight battery.
Old 12-27-2009, 02:20 AM   #12
birdman
From the sounds of it, a faulty battery cell might just be the culprit. Didn't leave anything open or on except its security systems blinking light like I usually do. There is no terminal corrosion or loose connections I can see. I will take it to the dealership and see what they say.
If they cant find anything wrong then I'll have to do something out of pocket. I guess that means I'd have to buy a new battery. I wonder how much it would cost from the dealership?
Thanks for all the insight. The YarisWorld community rocks!
Old 12-27-2009, 02:23 AM   #13
ezhacker1
ezhacker1's Avatar
for me (8 month old yaris) it has already failed to be charged twice, both times being do to negative terminal corrosion, (it looks like green power) Maybe cuz of the weather i have here, near the ocean.
Old 12-27-2009, 02:29 AM   #14
birdman
Ryu, Your LB is sweet!
Old 12-27-2009, 03:24 AM   #15
Revsson
I can't think of the product name, but there is a reddish spray you can
put on the terminals to help prevent corrosion. In the past, I have used
those little felt pads which worked pretty well, too.
Old 12-27-2009, 11:44 AM   #16
Kal-El
Kal-El's Avatar
If you can operate a wrench, by a battery from Wal*Mart or someplace affordable that sells batteries and do it yourself. It literally takes less than 5 minutes.
The stealership will charge you more than double for a 3 minute job. Like I said earlier, I got a battery for $65 at Wal Mart. The dealer will be over $120.
Old 12-27-2009, 01:11 PM   #17
Sidicas
The dome light in the Yaris goes through the ECU.. It shuts off automatically after 20 minutes no matter what..
Instead of paying money to have the dealer check the battery, just yank the battery out and take it down to Advance Auto parts.. Advance Auto Parts will check it for free..
Old 12-27-2009, 03:34 PM   #18
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
My stock battery quit holding a charge after 5,167 miles. I rid myself of the headache by getting a Napa Legend 7535 and have been fine since. I didn't bother going back to the dealer because I didn't need the hassle at 0 deg F. Not impressed with the oem battery-from day one the oem was weaker than the drinks at a church social. 75 bucks is cheap insurance.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 12:39 PM
Yaris does not start jake002 DIY / Maintenance / Service 21 01-05-2010 09:53 AM
Transmission designed for 10-15 min cold start delay Ironwill5 DIY / Maintenance / Service 29 12-03-2009 09:08 PM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 08:11 PM
Viper Remote Start goku87 In Car Entertainment + Electronics (audio / video / alarm) 4 12-13-2008 06:06 AM
