Old 11-02-2009, 01:44 AM   #109
Omu
Drives: 2009 Yaris
Originally Posted by the_boss View Post
can't imagine a yaris with 20' wheel
Like 4 years old kid wearing papa's shoes...
Omu is offline   Reply With Quote
Old 12-21-2009, 04:57 PM   #110
svgllmnt
Drives: 2007 Toyota Yaris
I have a no frills standard 2007 Yaris, and while I've browsed through this thread I guess my question still remains, so I hope you guys don't get upset with me for asking if this has been asked before.
I currently have the stock tires on my car (185/60R15) and its time to get new ones, but everywhere I go different stores are suggestion different size tires and I don't want to get something I don't need. I'm not looking for speed enhancing tires or anything like that, just basic, simple, boring tires.
Suggestions I have received have included tires that are 195/65R15 and even 175/65R14. Now I know the 14s won't fit on my car obviously, but would the 195/65R15's make a big difference? Would they even fit on my car?
I've never purchased tires on my own for a car so I want to make sure I'm not being sold something more expensive that I don't need.
Please help & again like I said I apologize if I missed a similar post with the same question.
svgllmnt is offline   Reply With Quote
Old 12-28-2009, 07:06 AM   #111
unclenefeesa
Da Uncle
Drives: 2008 Toyota Yaris Sedan
Best bet is to get tires with the same size the old ones (185/60R15) unless you where having trouble with them which I seriously doubt.
unclenefeesa is offline   Reply With Quote
Old 12-28-2009, 09:10 AM   #112
elmo
WFO
elmo's Avatar
Drives: 2008 hb
agree stock size is best, however i have 205/55/15's on my car no rubbing
elmo is offline   Reply With Quote
Old 01-03-2010, 07:02 PM   #113
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
does the bore on the new aftermarket rim have to be 54.1mm?
Old 01-03-2010, 07:07 PM   #114
Black Yaris
der Zeck
Black Yaris's Avatar
no, but new wheels usually have hub centric rings available that will snuggly fit the OE hub
they are not a must, but a good idea to help prevent vibration issues, I personally have not ran them, and I have yet to have a vibration problem with out them
Old 01-03-2010, 07:12 PM   #115
Black Yaris
der Zeck
well that is not entirely true. different tire sizes can be used to get a better ride, more performance or just better looks.
I ran 205/50R15's on my Yaris since it fit nicely on my 15x7 wheels with my 2 inch drop.... and it was one of the few sizes that BFG Super Sport A/S's came in at the time
everybody likes something different, that is why there are so many choices
Old 01-03-2010, 07:14 PM   #116
Black Yaris
der Zeck
Originally Posted by zarniko View Post
which tire should i use to put xxr513 15x7 with the DF210 springs so that it wont rub?..or is it not possible with the 7in width???
I ran 205/50R15's with the same setup, they fit with no problems what so ever
Old 01-03-2010, 07:14 PM   #117
1.5
Form>Function
1.5's Avatar
thanks black yaris! what a quick response
Old 01-03-2010, 07:15 PM   #118
Black Yaris
der Zeck
np, I was bored, just trolling the forum
Old 01-03-2010, 11:02 PM   #119
1.5
Form>Function
1.5's Avatar
typically the offset of a given wheel also refers to the lips size correct? The lower the offset the wider the lip? I just am having the hardest time finding the perfect wheel. I am trying to decide b/w either a 15x7.5 ET20 or a 16x7 ET40 (i want something deep dish and think these will have little to no lip) or a 16x7 ET20. My ideal wheel would be 16x7.5 ET20 would these even fit?
Old 01-03-2010, 11:41 PM   #120
Black Yaris
der Zeck
the offset refers to the surface where the wheel bolt to the hub
and you can have two wheels with the same offset and width, with different size lips
16x7.5 +20 would most likely poke out from the fender on a Yaris
Old 01-03-2010, 11:45 PM   #121
1.5
Form>Function
1.5's Avatar
ooooooo I get it so the offset more decides the concaveness of convexness of the face of the wheel itself. Im not worried about it poking out, Im trying to go hella flush or even a little past flush. I just want to make sure it wont rub or if I have to roll the fenders. So i cant really look at the offset to tell me the lip size?
Old 01-03-2010, 11:52 PM   #122
kimona
kimona's Avatar
Drives: 2014 White VITZ
Yeah, the offset will tell you nothing about the "lip size".
Any plans for suspension mods?
16x7, ET42 with 205 rubber will be just about flush up front, but tucked in the rear, so you may want to go with a 10mm rear spacer .
Old 01-03-2010, 11:56 PM   #123
1.5
Form>Function
1.5's Avatar
yes I plan on going with 5mm spacer in front and 10mm spacer in the rear, Im going super flush man lol, and i plan on going with some coilovers, havnt decided which yet, and camber kit.
Old 01-04-2010, 12:26 AM   #124
kimona
kimona's Avatar
You won't need spacers up front with 7's, ET42 and 205's.
Old 01-04-2010, 10:55 AM   #125
1.5
Form>Function
1.5's Avatar
ok true thanks.
Old 01-12-2010, 01:53 PM   #126
Inspector14
Drives: 09 Yaris hatch, Meteor Metal
ok i have been looking at that chart and am a bit confused. i ordered my summer tires and wheels (General Altimax HP on OZ Superturismo)
the wheels are 14x6 et 36 wrapped with 185/65-14 tires. tirerack has reservations on if these will fit. im sure they will. i just want to hear it from the gurus.
Inspector14 is offline   Reply With Quote
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 98 02-18-2024 06:45 AM
