Old 12-29-2009, 04:57 AM   #1
C_03
Drives: Yaris Silver
AMK HEADER
I BOUGHT A AMK HEADER AND DONT HAVE DE 02 SENSOR HOLE CAN I INSTALL WITHOUT THAT OR WHAT I CAN DO?
C_03 is offline   Reply With Quote
Old 12-29-2009, 09:06 AM   #2
jonismyname
Drives: 08 liftback 5spd
drill hole, weld bung.?
jonismyname is offline   Reply With Quote
Old 12-29-2009, 09:46 PM   #3
C_03
and thats looks good?
Old 12-29-2009, 10:09 PM   #4
ivanmadeline
ivanmadeline's Avatar
Drives: 2008 Yaris (Sedan)
Desde cuando se necesita eso en pr???????????????
ivanmadeline is offline   Reply With Quote
Old 12-29-2009, 10:13 PM   #5
YarisSedan
Drives: 08 Yaris Sedan
Find a mufflershop to drill a hole and weld a o2 bung. Its not that hard shouldnt cost you more than 50 bucks.
Old 12-29-2009, 10:32 PM   #6
C_03
jajajaj lo q pasa es q no quiero tener el chek engine prendio siempre
Old 12-29-2009, 10:36 PM   #7
ivanmadeline
como dice el de arriba llevalo a un muffler shop que te le anadan la tuerca para que le puedas adaptar el sensor. En la isla creo que lo hagan en todos los chop. por eso estrano la Isla tanto por los inventos que uno le puede hacer a los carros.
Old 12-30-2009, 04:47 AM   #8
C_03
SI LO Q QUIERO SABER ES Q SI DESPUES ESO SE VE FEO TAMBN ME DIJERON Q LO DEJARA ASI Y PUSIERA EL SENSOR AL PRINCIPIO DE LA TUBERIA DESPUES DEL HEADER
Old 12-30-2009, 10:01 AM   #9
sounds like you got a header for a first gen 1nzfe for an echo or xb....they don't have an 02 sensor bung like the yaris does.....and its not likely to line up w/ the midpipe
Old 12-30-2009, 07:40 PM   #10
C_03
I DONT KNOW BUT I BOUGHT THE HEADER ON EBAY AND SAID 07 + YARIS TAKE A LOOK
Old 12-30-2009, 10:04 PM   #11
YarisSedan
Sorry but you got what you paid for. I never really buy any car parts from ebay. Only thing i got from my yaris from ebay was fog lights and even those didnt fit right. Everything else its from reputable sources.
Old 12-30-2009, 10:06 PM   #12
YarisSedan
My friend bought a intake manifold from ebay once we had to sand down the flange where it mates to the cylinder head because it was such a horrible job. Not even a smooth flat surface. They are only mass produced cheap low quality parts which is why they are so cheap. Cheap and good are not general used in the same sentence.
Old 01-13-2010, 11:19 AM   #13
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
man when buying off ebay you really have to do your research. A good rule of thumb, never buy performance parts off ebay. Good luck tho.
Old 01-13-2010, 01:51 PM   #14
You have to have a bung and O2 (air/fuel) sensor on your header. If it's actually for an xB (first gen), you'll have trouble lining up the exhaust also.
Looks don't matter, the header goes behind the motor anyway.
Someone should report the seller for misrepresenting that product to fit the Yaris.
Old 01-13-2010, 10:20 PM   #15
1.5
Form>Function
1.5's Avatar
or you could file a dispute thru Paypal if you used them. One of the options for the dispute is "item did not match description" or something like that so you can file that and the seller will usually arrange a refund so he doesnt have bad marks against his ebay account.
Old 01-14-2010, 01:39 PM   #16
Caribe
Drives: 2008 Yaris hatchback
Le puedes soldar una tuerca con esa rosca detras del header, lo importante es que el sensor este antes del catalitico. En que pueblo estas?
Caribe is offline   Reply With Quote
Old 01-20-2010, 08:38 AM   #17
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
mhmm, i posted about this already. had a shop drill a hole and put a bung on it for the sensor. the collector doesnt fit perfectly to the midpipe like mentioned. possible leak, but ive been running it for months now without problems. made my yaris sound mean as hell though. people shit bricks when they hear it lol.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 01-20-2010, 11:16 AM   #18
1.5
Form>Function
1.5's Avatar
eii lets get a vid
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
AMK Racing Header eii Performance Modifications 55 07-11-2009 08:22 PM
Are We Still Stuck With the 4-1 Headers? Sabretooth Performance Modifications 31 02-20-2009 08:57 PM
