Old 01-04-2010, 09:13 AM   #1
Westlander
Drives: Yaris D4D 52
Question Interior dashboard lights
Hi all,
First post, although have just used the site to fix a blown fuse on my windscreen wiper....do you know how hard it is to find out info on fuses on the net!
I have had my Yaris for 2 years now and the old work horse has clocked up 122k miles. In that time i have driven at night time without any lights from the centre dashboard. The one that has the fan/heater dials on it.
At night time i cannot see anything here so its fun when im fumbling around trying to turn heat down etc.
IS THERE SUPOSE TO BE ANY ILLUMINATION HERE?
Other cars illuminate behind the switches so you can see them at night. Have i blown a fuse, what can i check ?
Thanks
Westlander is offline   Reply With Quote
Old 01-04-2010, 09:43 AM   #2
Does your car have the dimmer rheostat for the interior lights (pictured below)?
If so, it may be turned all of the way down. If not (as Yaris from some markets don't), then check the PANEL1 and PANEL2 fuse, which are under the bottom of the under dash fuse holder.
Old 10-20-2010, 02:26 AM   #3
Zomgk
Drives: 2006 Yaris YR
i have this problem as well no dimmer switch in my yaris. checked the fuses and they all seem fine thought it might be the bulbs but the are fine as well. this has got me beat
Zomgk is offline   Reply With Quote
Old 10-20-2010, 09:29 AM   #4
So, your Yaris has the digital cluster and not dimmer rheostat (the thing pictured above)?
When you turn the headlights on, does anything inside the car illuminate (power door lock/window switches, A/T shift lever indicator, etc.)?
dashboard, fan, heater, illuminate, interior
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 07:54 AM
Fog Lights Poll Reeves360 Cosmetic Modifications (Exterior/Interior) 14 12-27-2009 02:00 AM
Tail lights for 09 sedan piepie Cosmetic Modifications (Exterior/Interior) 7 06-03-2009 09:24 AM
Re-did lights, fixed scratch, RR floor mats! lots-o-pics dg4rez Photo-Video-Media Gallery 15 04-21-2009 01:45 AM
