Vitz_RS
Drives: Toyota Vitz RS NCP91 Join Date: May 2009
Engine Mounting
Hello,
Anyone know to check the Engine mounting support, if is ok or broken.. what is the negative effect you get when it is damage |
Learn to Relax
I would think that you would have problems with your CV joint or axle before the engine mount. You would hear a clunk sound when engaging the clutch or shifting.
Vitz_RS
its not when shifting, i get the clunk sound when holding the acceleration on first or second shift..like a knocking sound, sometime doesnt get it when fast shifting of first and second shift
Vitz_RS
anyone know part number of the engine mounting rear, left and upper..
for toyota vitz rs 1.5 NCP91 |
I get the same sound. Our cars dont have a front engine mount like 99 percent of all the other cars on the market. I supose to save cost and i guess they figured a economy car with small power engine wont have that much torque. But quick shifts will make the engine jerk a bit.
You can get a nitto torque dampner which does help a bit or a stiffer rear mount such as trd or a solid one. |
Vitz_RS
yes you right, we dont have front engine mount.
mine rear one is damage, do you know where i can order it. |
the rear one is underneath, also called the trans mount or "dogbone".
In the engine bay are the left and right engine mounts. Please describe the damage, there's not much that can go wrong with that.
Vitz_RS
Thanks for the help, do you know where to order or the part number of the 3 mount kit
![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
Looks like its time to order a trd one from garm then
Vitz_RS
yes TRD much better and torque, anyone know where to order online
Vitz_RS
diagram engine mount
http://www.toyodiy.com/parts/p_J_200...HMVK_1107.html |
YaYa
Drives: 2007 Yaris Liftback Join Date: Dec 2008
I just filled the voids in the "dogbone" mount with 3M window weld. It cut down on the movement ALOT, and it was 18 bucks for the tube @ pep boys.
shouldn't be too bad. The TRD one is harder rubber than stock, and it doesn't add much to the noise in the cabin.
YaYa
Not bad at all. I have always used stiff inserts in honda mounts for years, and the vibration in the Yaris with the window weld in the mount is not noticeable to me, but the engine movement is greatly reduced. I could feel the engine rocking back and forth before I did this, now I dont feel it rocking. I like it
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
