Old 01-14-2010, 09:31 PM   #217
Originally Posted by t2mike2 View Post
Hi guys im new here , joined because im getting my yaris tomorrow and was intrigued by this mod.
Can someone show me with microsoft paint maybe, how i can wire up this switch?
http://www.alliedelec.com/search/pro...px?SKU=9485541
~mkie~
Old 01-14-2010, 09:35 PM   #218
Where is the switch connector ?
This thread shows the details on the clutch switch connector:
http://www.yarisworld.com/forums/showthread.php?t=23510
Old 01-15-2010, 01:16 PM   #219
t2mike2
Drives: '10 Yaris 3 DR - Carmine Red
Thanks alot dude that is VERY very helpfull, very excited im going to pick up my yaris now. I'll post pics when this mod is done.
Thanks again.
~Mike~
t2mike2 is offline   Reply With Quote
Old 01-20-2010, 06:22 PM   #220
t2mike2
installed
done.
funny thing is i went to have it inspected... and the guy tells me...
"i hate to tell ya this ,... but the horn doesnt work....". Then it hit me... THATS what the black wire that i assumed did nothing was ! :p
Doesnt look pretty inside since i had to bootleggedly crimp alot of stuff but it works!
~mike~
Old 05-29-2010, 12:09 AM   #221
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
I'm going to try the 4 button set up and plan on getting it installed this weekend. I decided to put all the resistors in their own enclosure and attach the buttons with butt connectors. I can tuck the module up under the dash and if a button ever goes bad (read as: When I spill my drink into one), I can simply unplug the switch and replace it without any soldering. I have some buttons but I'm going to see if I can find something better.
I'll take more pics as I progress.
I couldn't find the right resistors so I had to stack them to get the right Ohm requirements.
I've got about $24 dollars into it so far.
Added more pics. I haven't settled on where I want the buttons or what type I want so I installed the cheap ones I had next to the Aux Port for now
I mounted the CC module on the cross bar under the steering wheel. The box has to lay on its bottom, not on its side as shown in the first picture of it. The steering column cover wont fit if it mounted on its side.
It works! CTScott, and everyone else that contributed, thank you for all the great info.
Last edited by Stove; 05-29-2010 at 06:53 PM. Reason: Updated and added more photos
Stove is offline   Reply With Quote
Old 07-06-2010, 03:32 PM   #222
drunix
Drives: 2010 Yaris 3D LB
How does that little panel pull out? (The "push button start cover".) Is there a trick to it? Thanks. I pulled it part way out and it seems to not want to part company with the panel on the right side.
drunix is offline   Reply With Quote
Old 08-11-2010, 03:59 AM   #223
birdman
Drives: '08 Blazing Blue Yaris LB
Ingenious!
birdman is offline   Reply With Quote
Old 08-11-2010, 09:38 AM   #224
You have to remove the vertical trim to the right of it first (which you can just pull off with your fingers as well).
Old 09-16-2010, 08:47 PM   #225
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
So in a sedan yaris 2009 you just have to do the switch mount and connect the red wire to the blue one and the black wire(ground) to the brown one of the d3 connector ? Am I right ?
Old 09-17-2010, 07:55 AM   #226
It depends on when in 09 the sedan was built. Some people with 09 sedans have found that the blue wire from the ECM to the steering column is not present. If it is, then the answer to your question is "Yes".
Old 09-17-2010, 11:23 PM   #227
packetrace
packetrace's Avatar
thank you Scott it worked perfectly :D It'S amazingg !!
Old 03-20-2011, 11:47 PM   #228
saltwt
Drives: Yaris
Correct. That's what I did with mine. In any vehicle that I've had with cruise, I never find myself using the tap up/down or coast/resume, so I just went with two switches.
Thanks for the great DIY...Im going to try it this week.... 2010 Yaris...Found the Icons for the Set & Cruise on the top left section of the Cluster panel.
saltwt is offline   Reply With Quote
Old 03-22-2011, 04:11 PM   #229
saltwt
Drives: Yaris
This worked out great! Had the job done in a hour...cost was under ten dollars..radio shack came threw with the buttons and resistors.
Thanks...
Old 03-25-2011, 03:55 PM   #230
Chuck
Drives: 2009 Yaris LB
Awesome! Just got mine done. $25.48 total. All parts from Radio Shack except for the splice/tap connectors. I forgot to get them while I was there, but grabbed them at advance auto parts for a little over a dollar. They are included in the price though. I got the red and black buttons (which came in one package), three pack of wiring: red, green, and black 20ga, 470ohm and 100ohm 1/4w resistors, 2 18-22ga splice/tap connectors (red), and the soldering iron kit. Thank you so much to those that put in the time to figure this out for the rest of us! :)
Chuck is offline   Reply With Quote
Old 04-01-2011, 05:28 PM   #231
mjmuck
Drives: 2008 1.5 L Yaris
I followed the instructions with the 4 switch method (minus installing the clutch switch) and even got a connector for the ecm to make sure it connects. I am still not getting this to work. I connected the ground to the metal bar underneath the steering wheel. I believe I made a good jump on the clutch connecter.
What problems have people had with this and the solutions? Maybe I'm just missing something silly. I'm trying to drive from KC to Chicago in a week and would really prefer this to work.
mjmuck is offline   Reply With Quote
Old 04-01-2011, 09:41 PM   #232
The biggest problems are typically bad connections or the ECM pin not being fully inserted. If you have a multimeter, with the ignition in the on position, measure the voltage at your switches where the ECM wire connects. It should read 12 V and then if you press and hold the on/off switch it should drop to 0 V.
Old 06-09-2011, 12:39 AM   #233
rob1987
Drives: 2007 yaris hatchback
dyi for cruise
hey was just curious i looked for the cc connector under the dash on my 07 yaris, cant seem to find.. Do not all of these cars have this connector? I dont see the yellow connector nor the one i need.. I pulled the drop down cover down, every side panel around steering wheel. Am i missing something or did they not all come with this?
rob1987 is offline   Reply With Quote
Old 06-09-2011, 07:54 AM   #234
All have it. You have to remove the lower steering wheel cover (the one that the tilt lever pokes through) to see it.
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
