Old 01-11-2010, 12:32 AM   #1
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Cowl Vent/Intake
just like to say a massive thanks to Micro Image and Garm
i Was going to put this in the performance section but until i get
the feeder hose hooked up it's there for looks
Old 01-11-2010, 12:36 AM   #2
ruimond
Drives: Yaris YR
Looks abit like a Rally car with that vent now Ray. Haha. Looks kinda cool. Something different!
Old 01-11-2010, 12:47 AM   #3
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
looks bigger then i expected
http://www.4055design.com
Old 01-11-2010, 01:19 AM   #4
^ You should see the one we're making for the USDM cars -- it's twice that width.
Old 01-11-2010, 02:55 AM   #5
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
so this for air going into the inside of the cabin right?
Check out my Build thread:
Old 01-11-2010, 04:22 AM   #6
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
Going into the cabin? That's unless you want to chop your way through the firewall lol....
This cowl/vent directs air into the engine bay and from there, you can direct flow to any region of the engine bay with some custom ducting.
Sponsored by: Micro Image
http://microimageonline.com
Old 01-11-2010, 05:00 AM   #7
ezhacker1
ezhacker1's Avatar
O HAHA, i didnt realize he was RHD, where the cabin air cowl is for us LHD.
Old 01-11-2010, 12:21 PM   #8
Correct, the replaces the access cover for the brake reservoir.
Old 01-11-2010, 12:48 PM   #9
2009BBPliftback
2009BBPliftback's Avatar
when/where can we get one for the usdm liftback?
2009BBPliftback is offline   Reply With Quote
Old 01-11-2010, 01:10 PM   #10
The piece is being developed by Micro Image. It will be available in our online store, and here is the development thread:
http://www.microimageonline.com/foru...ece-yaris.html
Old 01-11-2010, 09:36 PM   #11
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
Garm, can you get the RHD Cowl Vent for me as well?
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Old 01-11-2010, 11:08 PM   #12
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
He certainly can , PM him or myself .
Old 01-11-2010, 11:51 PM   #13
IsLNdbOi
IsLNdbOi's Avatar
I want one for my 5-door LB!
Old 01-12-2010, 12:05 AM   #14
jekqmb
Local Sh*t Disturber
Drives: 2009 Yaris LB
Garm can i pre-order???
Old 01-12-2010, 02:30 AM   #15
YarisSedan
Drives: 08 Yaris Sedan
There should be a sedan version!
Old 01-15-2010, 04:08 PM   #16
Yarisaur
Drives: 07 Yaris
Hey Garm! is this going to work on the Sedan? or is there going to be another one make to fit it? thanks bro!
Yarisaur is offline   Reply With Quote
Old 01-18-2010, 02:34 PM   #17
IllusionX
Drives: 07 Yaris Sedan Aero
lol omfg..
Garm: you have to make it for the sedan also!
Old 01-19-2010, 12:15 AM   #18
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Now, if someone would only develop an EXHAUST for cabin air, I know if 3 guys who would order one each right away! Getting the air in is no trick, getting it out is the problem. It has to fit in a low-pressure area, even if it means a sheetmetal job. On a sedan it isn't such a problem, as one can crack a rear window to let the air out; the flow through the cabin is much enhanced.
However, that doesn't work on a 3-door...
final installation of nology hotwires turboyaris Performance Modifications 28 05-14-2015 02:17 PM
Pic Request: Wiper Cowl Removed Sodium Duck DIY / Maintenance / Service 2 07-07-2009 12:23 AM
cowl induction cai andruboz Performance Modifications 4 02-06-2009 06:52 PM
metal cowl piece- paint or undercoat? andruboz Cosmetic Modifications (Exterior/Interior) 2 01-09-2009 05:14 PM
DIY - wiper cowl re-install kurokoma-kun DIY / Maintenance / Service 0 10-20-2008 02:05 PM
