Old 01-27-2010, 01:37 PM   #1
frankencar
Drives: 2010 Yaris S
2007 AT Yaris Disappoints me
Okay...
So I bought a used 2007 Yaris, AT, superbasic (no power anything). My wife and I share it, and though we're both conservative drivers - her a bit more than me - we're getting only 28-32mpg, typically getting 30 mpg on a tank. Now at first, I was okay with this because that's exactly what the EPA rating was, and for essentially an economy car it worked pretty well for our needs. However, after seeing these forums...I know there's a difference with the MT, and some hypermilers out there, but I've even seen some much higher claims for the AT. Which leads me to believe that either I've got a lemon, or there are lots of people out there who are calculating their mpg wrong
The one thing that concerns me is where the AT shifts. I haven't paid attention to it in awhile because I like my loud music in the car, but it seems to shift into fourth around 45mph, so when on the freeway going 55-65, the engine sounds like it's running at an unhealthy rpm. Is that normal? It seriously sounds like it needs an OD to me...but honestly I know nothing about gas cars. Electric is my thing. Please help! I'd love to solve this before my roadtrip in April.
frankencar is offline   Reply With Quote
Old 01-27-2010, 01:49 PM   #2
You're getting pretty much the norm for an AT, cold weather, winter formula gas. The claims of higher mpg are basically exceptions, and not the norm.
At 55-65 mph, your engine will be spinning at around 2800 - 3000 rpm. This again is normal for small displacement engines.
You have nothing here to worry about/fix before your roadtrip.
Old 01-27-2010, 03:05 PM   #3
eht13
Drives: .
I'm pretty sure that my AT sedan is at 3K or so RPM when cruising at 80MPH.
eht13 is offline   Reply With Quote
Old 01-27-2010, 03:13 PM   #4
b_hickman11
Drives: 08 Sedan
Originally Posted by frankencar View Post
Okay...
Wait until May or June to test your MPG.
Old 01-27-2010, 05:33 PM   #5
frankencar
Well as I said, I've had the car for awhile now and in no weather have I had more than 31mpg.
Old 01-27-2010, 05:51 PM   #6
MadMax
MadMax's Avatar
I've tracked my gas mileage in my 08 Yaris LB (with an auto) since getting it in November 2008, and it always decreases during the winter. Driving easy, I only get ~33 MPG during the winter, whereas I am closer to 37-38 MPG during the summer.
Secondly, are you sure you're not knocking the shift lever out of OD and into 3rd gear? It happens if you're not careful. I drive at 60 MPH on most of my commute and the car doesn't sound like it is stressing; but we are only talking a 1.5L 4-cylinder engine and a subcompact that isn't as sound-proofed as a bigger, luxury car. I usually crank up the radio as well, so I don't notice it either; but I have checked just to see how the engine is running at highway speeds (not having a tach stinks) and it appears fine to me.
Also, what kind of tires/rims are you running? I have aftermarket 17" rims and wider tires, which takes a bite out of my mileage. Friends with stock Yarii get better mileage...
Cheers! M2
Old 01-27-2010, 05:52 PM   #7
chew246214
Drives: 2009 yaris sedan base
Yep winter gas in the north east and dedicated snow tires.. mileage fell on it's face.... was doing well over 40 mpg matter of fact 44.6 average sedan a/t with regular tires and non winter gas.. now down to low to mid 30's... either way better then 12 in my truck i figure
chew246214 is offline   Reply With Quote
Old 01-27-2010, 05:55 PM   #8
MadMax
MadMax's Avatar
Winter gas is not limited to the northeast, we've got it down here in southcentral Texas...
Old 01-27-2010, 05:56 PM   #9
kargoboy
kargoboy's Avatar
Drives: '07 Yaris Sedan/'03 Protege
To the OP, where are you doing most of your driving?
And for the record, a lot of people don't know how to calculate their MPG correctly.
Even on this forum.
E-Present company excluded I am sure.
kargoboy is offline   Reply With Quote
Old 01-27-2010, 06:40 PM   #10
frankencar
Most of the driving is freeway, I'd say 70/30. Actually I have never heard of "winter gas..." there's literally a different gas pumped in winter?! I'm using all-season tires, stock size. I'm pretty sure I'm not knocking the shifter out of D, as I don't even get close to touching it. To my ear it still sounds like it's stressing, but like I said, not too experienced with cars/mechanical stuff.
Old 01-27-2010, 06:53 PM   #11
frankencar
Next chance I get, I'll take some video at high speed so maybe someone can give me an answer based on their experience.
Old 01-27-2010, 06:56 PM   #12
RETRO
Drives: 2008 Yaris Hatchback
you have 2 different drivers driving the car it will be hard to get a good mpg due to differnt driving habits..I get 38 mpg in my car when my wife drives it she gets 34 mpg..Winter gas is less quality than summer gas and you'll get about 2-3 mpg less than summer gas. In Alabama we have the crappy winter gas
RETRO is offline   Reply With Quote
Old 01-27-2010, 07:30 PM   #13
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Lots of hills in your area? Those high mpg numbers are definitely the exception as most of the drivers reporting them use hypermiling techniques. I average about 32mpg with mixed driving but always short trips and lots of hills.
Old 01-27-2010, 09:57 PM   #14
b_hickman11
Drives: 08 Sedan
You did not mention that in your first post.....
Old 01-27-2010, 10:01 PM   #15
b_hickman11
Drives: 08 Sedan
Remember there is more than 1 "D." Yes there is a winter gas and a summer gas. Winter gas will usually drop your mpg around 4 mpg on average based on the outside air temp.
Old 01-27-2010, 10:15 PM   #16
YAR1S
YAR1S's Avatar
lots of factors affect your ride.
check your air filter
make sure your tires are good and properly inflated
check spark plugs
calculate your mp3 accurately
dont jack rabbit from stoplights (my biggest pet peeve)
if your overweight = decreased mp3
declutter your car dont carry more than you need to
make sure you only AC when needed and dont leave defroster on
keep windows closed, a/c is just as bad on gas as wind resistence from open windows
use dfco, make sure your in "D" and not "3" to avoid hyper-revving.
those are the things that pop into my head when someone isnt getting good gas mileage.
-Jen <3
Old 01-27-2010, 10:50 PM   #17
supmet
Drives: 2007 4 Door Yaris
Even on this forum.
+1
My car only has one "D"
check spark plugs
Don't bother even thinking about your spark plugs until 30k. Don't check them til 60k.
Losing weight and decluttering your car will net you a whopping .00001 mpg
Typically air resistance doesn't catch up to the A/C until around 45 mph
Some 2007 yarii will only engage DFCO if you are in 3.
Especially when you throw in a learning ECU... .
To the OP: Don't let ridiculous internet claims ruin your love for your car.
Old 01-27-2010, 10:52 PM   #18
bear4
Drives: 2007 yaris
Well, we have 2 Echos - same engine as Yaris. One Echo is AT and the other one is a manual. The manual gets at least 42MPG even in the winter while the AT gets 32-34, so this is pretty typical...
bear4 is offline   Reply With Quote
automatic, fuel efficiency, mpg
