Old 01-19-2010, 12:05 PM   #1
matash
Drives: 2007 Yaris Sedan
keyless entry with tachometer
Have a 2007 Yaris Sedan with power windows/doors and a tachometer. The factory accessory keyless entry can not be installed on this car, because of the tachometer. Has anyone heard/found out why?
matash is offline   Reply With Quote
Old 01-19-2010, 03:55 PM   #2
That is totally bogus. There is nothing different about a car with a tach vs one without from the standpoint of factory keyless. If you want me to 100% verify that, let me know the part number on your car's ECM (under the hood, against the firewall on the passenger side).
Old 01-19-2010, 04:20 PM   #3
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I've got factory keyless entry on my 07 S sedan...same options plus CC and power mirrors. I doubt the options have much to do with the tach and the operation of the keyless entry.
It's going to be replaced with an Autopage alarm here in a few weeks though.
― Thomas Paine
Old 01-25-2010, 07:02 PM   #4
Reeves360
Drives: 09 Yaris Sedan, 91 ToyotaTruck
Send a message via AIM to Reeves360 Send a message via MSN to Reeves360 Send a message via Yahoo to Reeves360
OEM Alarm on Yaris w/ Tachometer
See my quote from another thread and some additional details below.
VIP Alarm V3
Originally Posted by Reeves360 View Post
It works!
The only minor issue that I can see why Toyota says not to install this alarm system with our Yari that have a tachometer is because you will get a error beep when trying to arm the system when the dome light is still on.
I'm assuming the reason for the error beep is because the door ajar light shares the same circuit as dome light. Hence when you try to arm the alarm with the dome light still on the alarm system thinks that one of your doors is not closed all the way and give you an error beep to let you know you need to check.
This part is very important, "If you purchase the power package you get a tachometer and a DIMMING DOME LIGHT, which is what causes the problem."
Toyota will not install this alarm into a Yaris with a tachometer because Toyota the Manufacture says NO. Toyota will install a factory alarm system (VIP) into any Yaris that doesn't have a tachometer.
Hope this helps.
Reeves360 is offline   Reply With Quote
Old 01-25-2010, 09:30 PM   #5
VIP Alarm V3
Hope this helps.
Interesting. The solution is to use the door courtesy switch inputs to the ECM rather than the ILE output from the ECM as the door closed/ajar feed to the VIP.
Old 01-26-2010, 03:07 PM   #6
Reeves360
Sweet! Would you mind showing me which colored wires I should move from the ILE to the ECM?
So it sounds like if I move the door ajar wires from the alarm systems factory designated location (ILE?) to another location (ECM?) that would tell the alarm the doors are closed when they are even if the dome light is still on?
Hopefully I have this concept correct.
Thank you for the help CTScott!
Old 01-26-2010, 03:14 PM   #7
You have the concept correct. Let me take a look at the VIP install manual and I'll give you the info. You won't have to run any wires to the ECM. The change will take place right at the under dash fuse panel area.
Old 01-27-2010, 11:15 PM   #8
So, I checked out the TVIP wiring diagrams. It looks like the way that the door input is wired, if you put the dome light in the "off" instead of "door" position, the TVIP will either not arm, or will not detect the door being opened. Can you try that to confirm?
Old 01-28-2010, 06:28 PM   #9
Reeves360
I tried that 1st thing to see if it fixes the issue but it doesn't. I think that it's because of a capacitor or something that stores a small charge once all the doors are close it "leaks" the stored power to the dome light for about 7 seconds. So that the customer will get a nice light that auto dims off.
Even if you turn off the light at the switch power is still being stored and leaked out every time the doors are open and shut.
Old 01-28-2010, 07:14 PM   #10
I wasn't expecting it to be a fix. I just wanted to check to see if it behaves differently with the switch in one position or the other. If it does not, then I have to dig some more into how the TVIP gets the door status from the body ECU (which is a computer that is within the under dash fuse panel).
Old 01-29-2010, 01:17 PM   #11
3stars_n_a_sun
3stars_n_a_sun's Avatar
Drives: 2008 yaris sedan
wow interesting read. i have a question coz i've been planning on putting a keyless entry on my sedan and i have the power package / tachometer. i'll be getting a cheap viper keyless entry from best buy will it still give me an error even though i let the professional install it?
3stars_n_a_sun is offline   Reply With Quote
Old 01-29-2010, 02:41 PM   #12
An aftermarket one is installed completely different than the Toyota TVIP RS3200 Alarm or Toyota OEM keyless entry. So, you wouldn't encounter the issue being discussed in this thread.
Old 01-29-2010, 04:36 PM   #13
3stars_n_a_sun
i thought we can encounter the same problem with the oem ones. thanks CTScott for clearing that up.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 02:32 PM
Factory Keyless Entry LR118 In Car Entertainment + Electronics (audio / video / alarm) 18 11-12-2008 08:46 AM
keyless entry? / security? mem In Car Entertainment + Electronics (audio / video / alarm) 8 10-22-2008 02:29 AM
Aftermarket Keyless Entry - How does it affect the Warranty? aerock19 In Car Entertainment + Electronics (audio / video / alarm) 7 09-07-2007 03:11 PM
I want keyless entry!!! Lillydot General Yaris / Vitz Discussion 7 03-20-2007 11:46 PM
